Embedded and Microcontrollers
Documents Tech First Kit-Olimex-AT90USB162-USB-EVB
  • Author Author: tech5
  • Date Created: 8 Jan 2010 9:36 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:54 AM
  • Views 1359 views
  • Overview
  • Key Features
  • Ordering Information
Overview
AT90USB162 is the easiest way to add USB functionality to your next device, Atmel provide free open source HID (mouse, keyboard) and CDC (USB-to-RS232) code and on top of this AT90USB162 cost is same as ATMega16, so what you are waiting for? AVR-USB-STK board allows all USB features of AT90USB162 to be explored. The boards have USB connector, Joystick, RS232, SD-MMC card, Audio output, ICSP connector and extension connector. All AT90USB162 come from Atmel pre-programmed with bootloader which allow code to be programmed inside the chip without any external programmer, just download the FLIP software from Atmel web site and load your HEX code inside AT90USB162. To enter the bootloader mode you should press and hold HWB button, then press and release RST button. If you prefer to use ICSP programmer note that only AVR-ISP-MK2 is supporting AT90USB162 as there are pretty new devices, probably AVR Dude will add support later, but for the moment you can't use AVR-PG1 or AVR-PG2 for ICSP programming, another bad news is that AT90USB162 supports only debug Wire not JTAG so to debug it you should have the expensive AT-JTAGICE-MK2.
Key Features
  • AT90USB162 microcontroller with 16KB Flash, 512B RAM, 512B EEPROM
  • ICSP 5x2 pin connector for in-circuit programming with AVR-ISP-MK2 (you generally don't need to use ICSP as you can program via USB)
  • Debug Wire could be performed by 3 wires connected to ICSP (AT-JTAGICE-MK2 have such lose wire connector which to be used, you need VCC, GND, RST signals only)
  • USB 2.0 Full speed connector
  • RS232 driver and connector
  • SD-MMC card connector
  • Audio out 3.5 mm jack connector
  • Extension connector with AVR port signals
  • Status LED
  • Joystick
  • User button HWB (can be used to enter bootloader mode after reset)
  • Reset button RST
  • Takes power from USB no need for external adapter
  • External power supply and voltage regulator if USB can't provide enough power
  • Quartz crystal oscillator circuit 8Mhz
  • Extension pin headers for each uC pin
  • Four mounting holes 3.3 mm (0.13")
  • Grid 100 mils
  • GND bus
  • Vcc bus
  • FR-4, 1.5 mm (0,062"), green soldermask, white silkscreen component print
  • Dimensions 100x80 mm (3.9x3.15")
      Ordering InformationBack to Top
      Supplier
      Part Number
      Olimex
      AVR-USB-STKAVR-USB-STK
      Associated Products
      Supplier
      Description
      Part Number
      Atmel
      8-bit Microcontroller with USB Controller
      AT90USB162AT90USB162
      Maxim
      RS232 transceivers
      MAX3232MAX3232
      ST Micoelectronics
      1W, Class AB, Audio Amplifier
      TS4871TS4871
      National Semiconductor
      Voltage Regulator
      LM1117DT-ADJLM1117DT-ADJ
      VIDEK
      DB9 Plug
      81008100
      Similar Products
      SupplierDescriptionSupport DevicePart Number
      Atmel
      AVR USB Mass Storage Add-on
      AT90USBxxx
      ATEVK525ATEVK525
      Olimex
      AVR USB Board
      AT90USB162
      AVR-MT128AVR-MT128
      Document ListBack to Top
      Datasheet
      Part Number
      Description
      Size
      AT90USB162
      8-bit Microcontroller with Flash and USB Controller
      3.8MB
      MAX3232
      RS-232 Transceivers
      752KB
      TS4871
      1.45MB
      LM1117DT-ADJ/NOPBLM1117DT-ADJ/NOPB
      800mA Low-Dropout Linear Regulator
      647KB
      Application Notes
      File Name
      Size
      AVR040: EMC Design Considerations
      105KB
      AVR042: AVR Hardware Design Considerations
      196KB
      AVR103: Using the EEPROM Programming Modes
      76KB
      AVR105: Power efficient high endurance parameter storage in Flash memory
      145KB
      AVR130: Setup and use the AVR Timers
      179KB
      Hardware & Software
      File Name
      Size
      AVR-USB-STK-SCH-REV-A.pdf
      370KB
      1.29KB
      AVR-USB-STK-MOUSE.zip
      1.84MB
      AVR-USB-STK-CDC.zip
      1.49MB
      AVR-USB-STK-MASS-STORAGE.zip
      158KB
      AVR-USB-STK-DEMO.zip
      154KB
    • at:evaluation_board
    • ap:usb
    • sp:olimex
    • at:tech_first_kit
