Embedded and Microcontrollers
Documents Tech First Kit-Olimex-ATMega16-MCU-EVB
  • Author Author: tech2
  • Date Created: 11 Jan 2010 3:58 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:54 AM
  • Views 589 views
  • Overview
  • Key Features
  • Ordering Information
Overview
AVR-IO-M16 is small but powerful board, perfect for small automation projects. The board has four Relays with 10A/250VAC current switching capabilities, four optocoupler digital inputs and RS232 port. One of our demo software shows how easy is to control the inputs and output by PC computer through the RS232 port.
Key Features
  • ATMega16-16AI
  • ICSP 5x2 pin connector for in-circuit programming with AVR-PG1, AVR-PG2, AVR-ISP500, AVR-ISP500-TINY, AVR-ISP500-ISO or other compatible to 10 pin ICSP layout
  • JTAG 5x2 pin connector for in-circuit programming with AVR-JTAG, AVR-JTAG-USB or other compatible to 10 pin JTAG layout
  • status LED
  • reset IC ZM33064
  • Quartz crystal oscillator circuit 16MHz
  • Voltage regulator +5V, 7805 and filtering capacitors
  • Power plug-in jack
  • RS232 DB9 female connector , RS232 and interface circuit with Tx, Rx signals
  • 4 optocoupler isolated inputs with screw terminals
  • input status LEDs
  • 4 relay outputs with 5A/250VAC contacts with screw terminals
  • output status LEDs
  • four mounting holes 3.3 mm (0.13")
  • FR-4, 1.5 mm (0.062"), green soldermask, white silkscreen component print
  • dimensions 80x100 mm (3.9 x 3.15")
Ordering InformationBack to Top
Supplier
Part Number
Olimex
AVR-IO-M16AVR-IO-M16
Associated Products
Supplier
Description
Part Number
Ateml
8Bit 16K Flash MCU
ATMEGA16-16AUATMEGA16-16AU
Vishay
Optocoupler Transistor,  5300VRMS
4N374N37
Onsemi
5V, Voltage Regulator
MC78L05ABDGMC78L05ABDG
Videk
DB9 Plug
81008100
Similar Products
SupplierDescriptionSupport DevicePart Number
Olimex
AVR-GSM - BOARD
ATMega32
AVR-GSMAVR-GSM
Olimex
ATMEGA128 BOARD
ATMega128-16AI
AVR-MT128AVR-MT128
Olimex
AVR Smart Battery Ref Design
ATmega16HVA, ATmega8HVA
ATAVRSB200ATAVRSB200
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
ATmega16
8-bit Microcontroller with 16K Bytes
2.80MB
4N37
Optocoupler, Phototransistor Output, with Base Connection
112KB
MC78L05A
3-Terminal 0.1A Positive Voltage Regulator
188KB
Application Notes
File Name
Size
AVR040: EMC Design Considerations
105KB
AVR042: AVR Hardware Design Considerations
196KB
AVR103: Using the EEPROM Programming Modes
76KB
AVR105: Power efficient high endurance parameter storage in Flash memory
145KB
AVR130: Setup and use the AVR Timers
179KB
Hardware & Software
File Name
Size
AVR-IO-M16-SCH-REV-A.pdf
276KB
avr-io-m16_UART.zip
16KB
avr-io-m16_UART.hex
10KB
  • at:evaluation_board
  • ap:mcu
  • sp:olimex
  • at:tech_first_kit
