Embedded and Microcontrollers
Documents Tech First Kit-OLIMEX-STM32-103STK-MCU-Dev Kit
  • Author Author: tech5
  • Date Created: 8 Jan 2010 5:41 AM Date Created
  • Last Updated Last Updated: 27 Oct 2013 2:25 AM
  • Views 662 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The ARM Cortex-M3 processor is the latest generation of ARM processors for embedded systems. It has been developed to provide a low-cost platform that meets the needs of MCU implementation, with a reduced pin count and low-power consumption, while delivering outstanding computational performance and an advanced system response to interrupts. The ARM Cortex-M3 32-bit RISC processor features exceptional code-efficiency, delivering the high-performance expected from an ARM core in the memory size usually associated with 8- and 16-bit devices.
The STM32F103 Performance Line family has an embedded ARM core and is therefore compatible with all ARM tools and software. It combines the high performance ARM Cortex-M3 CPU with an extensive range of peripheral functions and enhanced I/O capabilities. STM32-103STK is starterkit board which allow you to explore all STM32F103 capabilities. It have NOKIA 3310 BW 84x48 LCD, buttons, SD-MMC card, Accelerometer, 2.4Ghz RF transciever, Audio Input and Output, the power supply is made from single 1.5V AA cell battery.
Kit Contents
  • STM32-103STK Starterkit board
  • STM32F103RBT6 microcontroller
Key FeaturesBack to Top
  • MCU: STM32F103RBT6 ARM 32 bit CORTEX M3Tm with 128K Bytes Program Flash, 20K Bytes RAM, USB, CAN, x2 I2C, x2 ADC 12 bit, x3 UART, x2 SPI, x3 TIMERS, up to 72Mhz operation
  • Standard JTAG connector with ARM 2x10 pin layout for programming/debugging with ARM-JTAG
  • USB mini connector
  • LCD NOKIA 3310 BW 84x48 pixels
  • 1.5V battery connector with step-up converter
  • 3-axis accelerometer
  • SD-MMC card
  • 2.4 Ghz transciever with Nordic nRF23L01
  • Audio input
  • Audio output
  • User buttions x2
  • Joystick with 4 directions and push action
  • UEXT connector for other Olimex's modules connection like MOD-MP3, etc
  • RESET button
  • Status LED
  • 8 Mhz crystal oscillator
  • 32768 Hz crystal and RTC backup battery connector
  • Extension headers for all uC ports
  • PCB: FR-4, 1.5 mm (0,062"), soldermask, silkscreen component print
  • Dimensions: 90 x 65mm (3.5 x 2.5")
      Ordering InformationBack to Top
      Supplier
      Part Number
      OLIMEX
      STM32-103STKSTM32-103STK
      Associated Products
      Supplier
      Description
      Part Number
      TYCO Electronics
      HEADER, BOX, STRAIGHT, 10WAY
      1-1634688-01-1634688-0
      Vishay
      POTENTIOMETER, 2W 10K
      534B1103JLB534B1103JLB
      DURACELL
      BATTERY, PROCELL, AA, PK638
      1503362615033626
      VARTA
      BATTERY, ALKALINE, AA, PK4
      41062103944106210394
      ST Microelectronics
      32-Bit Microcontroller Controller Family/Series:(ARM Cortex) STM32; Memory Size, RAM:20KB;
      STM32F103RBT6STM32F103RBT6
      Similar Products
      SupplierDescriptionSupport DevicePart Number
      OLIMEX
      KIT, DEV, ST ARM CORTEX M3 BOARD
      STM32F103RBT6
      RSTM32-P103RSTM32-P103
      Document ListBack to Top
      Datasheet
      Part Number
      Description
      Size
      STM32-103STK
      STM32-103STK Users Manual
      910KB
      Application Notes
      File Name
      Size
      Code Composer Studio tutorial how to use TMS320-P28016 board
      153KB
      Flash programming on TMS320-P28016
      543KB
      STM32F10xxx devices: advanced I²C examples
      153KB
      How to get the best ADC accuracy in STM32F10xxx devices
      122KB
      Oscillator design guide for ST microcontrollers
      71.3KB
      STM32F10xxx internal RC oscillator (HSI) calibration
      1.5MB
      Implementing the ADPCM algorithm in high-density STM32F103xx microcontrollers
      72.9KB
      STM8S and STM32Tm MCUs: a consistent 8/32-bit product line for painless migration
      153KB
      How to migrate from the STM32F10xxx firmware library V2.0.3 to the STM32F10xxx standard peripheral library V3.0.0
      122KB
      Hardware & Software
      File Name
      Size
      http://www.olimex.com/dev/images/ARM/ST/STM32-103STK-REV-B-sch.gif
      64KB
      JTAG connector (top view)
      63.7KB
      Blinking LED C source and project for EW-ARM 5.11
      122KB
      Sample mouse driver with accelerometer, USB Audio device, USB Mass Storage, USB-to-RS232 Virual COM port, Maze game with accelerometer and LCD C source and project for EW-ARM 5.11
      71.3KB
      USB Virtual COM port and bi-directional RF link between two STM32-103STK C source and project for EW-ARM 5.11
      1.5MB
      STM32-103STK test code shipped with every board for EW-ARM 5.11
      72.9KB
      Blinking LED project for GCC + Eclipse + OpenOCD
      153KB
      OpenOCD + Eclipse set of projects 1.00 include flash write make file for STM32-103STK
      122KB
      Other Resources
      File Name
      Size
      The complete list of projects
      63.7KB
    • at:development_kit
    • ap:mcu
    • sp:olimex
    • at:tech_first_kit
