Embedded and Microcontrollers
Documents Tech First Kit- OLIMEX-SAM7-EX256-ARM-EVB
  • Author Author: tech5
  • Date Created: 8 Jan 2010 11:18 AM Date Created
  • Last Updated Last Updated: 6 Apr 2010 9:11 AM
  • Views 875 views
  • Overview
  • Key Features
  • Ordering Information
Overview
SAM7-EX256 is the Development board for ARM7TDMI-S microcontroller.
Key Features
The SAM7-EX256 has the following features:
  • MCU: AT91SAM7X256 16/32 bit ARM7TDMITm with 256K Bytes Program Flash, 64K Bytes RAM, CAN, USB 2.0, Ethernet 10/100, RTT, 10 bit ADC 384 ksps, 2x UARTs, TWI (I2C), 2x SPI, 3x 32bit TIMERS, 4x PWM, SSC, WDT, PDC (DMA) for all peripherals, up to 55 MHz operation
  • Standard JTAG connector with ARM 2x10 pin layout for programming/debugging with ARM-JTAG
  • NOKIA 6610 128x128 TFT 12 bit COLOR LCD with back light
  • Ethernet 10/100 PHY with KS8721BL
  • USB connector
  • Two channel RS232 interface and drivers
  • SD/MMC card connector
  • Joystick with 4 direction and push action
  • Two buttons
  • Audio in and Audio Out jacks for microphone and headphones
  • On board Speaker with volume control potentiometer
  • Trimpot connected to ADC
  • Thermistor connected to ADC
  • On board voltage regulator 3.3V with up to 800mA current
  • Single power supply: 6V AC or DC required, board can take power from USB port too
  • Power supply LED
  • Power supply filtering capacitor
  • RESET circuit , RESET button
  • 18.432 Mhz crystal on socket
  • Extension headers for all uC ports
  • PCB: FR-4, 1.5 mm (0,062"), soldermask, silkscreen component print
  • Dimensions: 128 x 98 mm (5 x 3.8")
      Ordering InformationBack to Top
      Supplier
      Part Number
      Olimex
      SAM7-EX256SAM7-EX256
      Associated Products
      Supplier
      Description
      Part Number
      Atmel
      MCU, 32BIT, ARM7, 256K FLASH
      AT91SAM7X256B-AUAT91SAM7X256B-AU
      MICREL
      PHY Transceiver
      KSZ8721BLKSZ8721BL
      MAXIM
      RS232 Transceiver
      MAX3232IPWMAX3232IPW
      Microchip
      High-Speed CAN Transceiver
      MCP2551-E/PMCP2551-E/P
      ON Semiconductor
      1.5 A, Step-Up/Down/ Inverting Switching Regulators
      MC34063ADGMC34063ADG
      Similar Products
      SupplierDescriptionSupport DevicePart Number
      Olimex
      ATMEL AT91SAM7S256 DVB
      AT91SAM7S256
      SAM7-P256SAM7-P256
      Document ListBack to Top
      Datasheet
      Part Number
      Description
      Size
      AT91SAM7X256B-AU
      highly integrated Flash microcontrollers based on the 32-bit ARM RISC processor
      764KB
      MC34063ADG
      1.38MB
      KSZ8721BL
      PHY Transceiver
      766KB
      MAX3232IPW
      RS232 Transceiver
      609KB
      MCP2551-E/P
      349KB
      MC34063ADG
      159KB
      Application Notes
      File Name
      Size
      Using the Memory Protection Unit (MPU) on AT91SAM7SE Microcontrollers
      296KB
      Using the Serial Peripheral Interface with AT91SAMxx Devices
      194KB
      AT91SAM7SE Microcontroller Series Schematic Check List
      681KB
      AT91SAM7X and AT91SAM7XC Microcontroller Series Schematic Check List
      700KB
      Using Low Power Modes in AT91SAM7L Microcontrollers
      681KB
      Using a Real-time Timer with Non-calibrated RC Oscillator as Real-time Clock
      210KB
      Interfacing Fast Ethernet Transceivers to MAC Processors
      122KB
      Design Guide for Interchangeability
      113KB
      A CAN Physical Layer Discussion
      258KB
      Interface Products Design Guide
      781KB
      A Simple CAN Node Usiing the MCP2510 and PIC12C67X
      334KB
      A CAN System Using Multiple MCP25050 I/O Expanders
      415KB
      Smart Sensor CAN Node using the MCP2510 and PIC16F876
      470KB
      Hardware & Software
      File Name
      Size
      SAM7-EX256 REV.B schematic
      173KB
      TCP-IP code with FreeRTOS
      1.66MB
      BMP-TO-ARRAY converter for Nokia 6610 LCD
      34KB
      OpenOCD + Eclipse set of projects 1.00 include flash write make file for SAM7-EX256
      2.79MB
    • at:evaluation_board
    • ap:arm
    • sp:olimex
    • at:tech_first_kit
