Embedded and Microcontrollers
Documents Tech First Kit-Olimex-ATMega128-MCU-EVB
  • Author Author: tech2
  • Date Created: 11 Jan 2010 3:58 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:54 AM
  • Views 1241 views
  • Overview
  • Key Features
  • Ordering Information
Overview
AVR-MT128 is simple but powerful board which uses the MCU ATMega128 from Atmel. With its LCD, button, relay and variety of interfaces such as RS232 (in two variants – 4 pins and DB9), JTAG, ISCP, Dallas, etc. this board is suitable for different embedded systems applications.
Key Features
  • MCU: ATMega128-16AI with128K Bytes Program Flash, 4K Bytes data EEPROM, 4K Bytes RAM
  • JTAG connector for in-circuit programming and debugging with AVR-JTAG
  • ICSP 5x2 (10) pin STKxxx compatible connector for in-circuit programming with AVR-PG1B or AVR-PG2B
  • RS232 connector with TTL levels
  • RS232 interface circuit with Tx, Rx signals
  • RS232 DB9 female connector
  • Dallas touch button port
  • Frequency input
  • LCD 16x2 display
  • LED status
  • five buttons
  • Buzzer
  • power supply circuit +5V, 78L05 with plug-in power jack and diode bridge
  • 32 768 Hz oscillator crystal
  • 16 MHz crystal oscillator
  • power supply filtering capacitor
  • RESET supervisor IC ZM33064
  • RELAY with 10A/250VAC NO and NC contacts with screw terminals
  • extension headers for unused in the schematic ports available for external connection
  • PCB: FR-4, 1.5 mm (0,062"), green soldermask, white silkscreen component print
  • four mounting holes 3.3 mm (0.13")
  • Dimensions: 120x38 mm (4.7x1.5")
Ordering InformationBack to Top
Supplier
Part Number
Olimex
AVR-MT128AVR-MT128
Associated Products
Supplier
Description
Part Number
Ateml
8Bit 16K Flash MCU
ATMEGA128-16AUATMEGA128-16AU
Onsemi
5V, Voltage Regulator
MC78L05ABDGMC78L05ABDG
Videk
DB9 Plug
81008100
Similar Products
SupplierDescriptionSupport DevicePart Number
Olimex
AVR-GSM - BOARD
ATMega32
AVR-GSMAVR-GSM
Olimex
ATMEGA128 BOARD
ATMega128-16AI
AVR-MT128AVR-MT128
Olimex
AVR Smart Battery Ref Design
ATmega16HVA, ATmega8HVA
ATAVRSB200ATAVRSB200
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
ATmega128
8-bit Microcontroller with 16K Bytes
6.06MB
MC78L05A
3-Terminal 0.1A Positive Voltage Regulator
188KB
Application Notes
File Name
Size
AVR040: EMC Design Considerations
105KB
AVR042: AVR Hardware Design Considerations
196KB
AVR103: Using the EEPROM Programming Modes
76KB
AVR105: Power efficient high endurance parameter storage in Flash memory
145KB
AVR130: Setup and use the AVR Timers
179KB
Hardware & Software
File Name
Size
AVR/AVR-MT-128-SCH-REV-A.pdf
26KB
1.4KB
2KB
avr-mt-128-test.zip
4.25KB
avr-mt-128_Display.zip
15.8KB
avr-mt-128_Relay.zip
7.35KB
avr-mt-128_Miscellaneous.zip
15KB
  • at:evaluation_board
  • ap:mcu
  • sp:olimex
  • at:tech_first_kit
