Embedded and Microcontrollers
Documents Tech First Kit-Olimex-PIC-P67J60-Ethernet-EVK
  • Author Author: tech4
  • Date Created: 11 Jan 2010 6:07 AM Date Created
  • Last Updated Last Updated: 6 Apr 2010 7:11 AM
  • Views 1097 views
  • Overview
  • Key Features
  • Ordering Information
Overview
If you want to build your own Internet enabled device this is the board for you. It has PIC18F67J60 microcontroller which has integrated Ethernet MAC+PHY and comes pre-programmed with Microchip's free TCP-IP stack. So all you need is to add your circuit in the prototype area and you are ready! With 128K Flash memory for programs and 128KB Flash memory your application will not suffer from low memory at all.
Key Features
The PIC-P67J60 prototype board has the following features:
  • PIC18F67J60 microcontroller with Ethernet and 1Mbit memory for code
  • 1Mbit data Flash for data storage
  • Mini ICSP/ICD connector for programming with PIC-ICD2
  • Ethernet connector with status LEDs
  • RS232 driver and connector
  • Complete web server and TCP-IP stack support as per Microchip's open source TCP-IP stack
  • All PIC free ports available on header close to the prototype area
  • Dimensions 100x80 mm (3.94 x 3.4")
Ordering InformationBack to Top
Supplier
Part Number
Olimex
PIC-P67J60PIC-P67J60
Associated Products
Supplier
Description
Part Number
Microchip
8-Bit Microcontroller IC
PIC18F67J60-I/PTPIC18F67J60-I/PT
Similar Products
SupplierDescriptionSupport DevicePart Number
Microchip
Internet Radio Demo Board
PIC18F67J60
DM183033DM183033
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
PIC18F67J60
PIC18F97J60 Family Data Sheet
7.56MB
Application Notes
File Name
Size
Understanding PIC WEB Boards And How to Use Microchip’s TCP-IP Stack
497.68KB
MiWi Wireless Networking Protocol Stack
634.46KB
Emulating Data EEPROM for PIC18 and PIC24 MCUs and dsPIC DSCs
368KB
Microchip MiWi P2P Wireless Protocol
370.95KB
Class B Safety Software Library for PIC MCUs and dsPIC DSCs
398KB
Microchip TCP/IP Stack Application Note
429.14KB
An SNMP Agent for the Microchip TCP/IP Stack
564.53KB
Hardware & Software
File Name
Size
PIC-P67J60 Schematic
60.5KB
Microchip TCP-IP Stack 5.00 modified for PIC-P67J60
432KB
    • ap:ethernet
    • at:evaluation_kit
    • sp:olimex
    • at:tech_first_kit
