Embedded and Microcontrollers
Documents Tech First Kit-Renesas-R0K561622S000BE-EVK
  • Author Author: tech5
  • Date Created: 6 Jan 2010 10:53 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:54 AM
  • Views 593 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The Renesas Starter Kit for H8SX/1622F is intended as a user-friendly introductory and evaluation tool for the H8SX/1622 microcontroller. The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E10A emulator.
The Renesas Starter Kit for H8SX/1622F may be connected to the host PC using a simple RS232 serial connection or via the included USB E10A on chip debugging interface.
The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools.
Kit Contents
  • CPU Board
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • E10A-USB for Starter Kit
  • Connection Cable (USB Cable, User Interface Cable)
  • Multi region 5V power supply
  • Quick Start Guide
  • CD-ROM
    • Documents : User Manual, Tutorial, and more
    • IDE : High-performance Embedded Workshop
    • C/C++ Compiler : C/C++ Compiler Package for SuperH Family Evaluation Version
    • Debugger : E10A-USB Emulator Debugger
Key FeaturesBack to Top
  • CPU
    • 32-bit bus
    • Power supply voltage: 3.0-3.6 V
    • Maximum operating frequency: 50 MHz
    • Executes basic instructions in 1 state
    • 32-bit internal multiplier/ divider
  • Internal memory
    • H8SX/1622F (Flash 256 KB, RAM 24KB)
  • Bus controller (BSC)
  • DMA controller (DMAC) : 2 ch
  • Data transfer controller (DTC)
  • I/O ports: 74input/output ports, 17input ports
  • 16-bit timer pulse unit (TPU) : 6 ch
  • Programmable pulse generator (PPG)
  • 8-bit timers (TMR) : 4 ch
  • High precisio A/D converters 16bit delta sigma ADC : 6 ch
  • User break controller (UBC)
  • New A/D converters : High-speed A/D converters 8 ch
  • D/A converters: 2 ch
  • Serial communication interface(SCI) : 5 ch
    • Asynchronous/ clocked synchronous
    • Smart card I/F : 5 ch
  • Boundary scan function supported
  • I2C bus: 2 ch
  • Operating modes: 6 operating modes
  • Package
    • LQFP-144V  (FP144LV)
    • TFLGA-145V (TLP-145V)
  • Development environment
    • Full ICE (E6000H) *Restrictions
    • On-chip emulator (E10A-USB)
Ordering InformationBack to Top
Supplier
Part Number
RENESAS
R0K561622S000BER0K561622S000BE
Associated Products
Supplier
Description
Support Device
Part Number
MAXIM
Transceiver IC
Transceiver
MAX3222CUP+MAX3222CUP+
SWITCHCRAFT
DC Power Jack
JACK SOCKET, DC
RAPC712XRAPC712X
BOURNS
TRIMMER, 10K
potentiometer
3386F-1-103TLF3386F-1-103TLF
TYCO ELECTRONICS / AMP
PLUG, D, 40-40UNC, 9WAY
connector
3-338168-23-338168-2
Similar Products
SupplierDescriptionSupport DevicePart Number
RENESAS
Starter Kit for H8SX/1648F
R5F61648N50FPV
R0K561648S000BER0K561648S000BE
RENESAS
Starter Kit for H8SX/1664F
R5F61664N50FPV
R0K561664S001BER0K561664S001BE
RENESAS
Starter Kit for SH7124
R5F71242D50FP
R0K571242S001BER0K571242S001BE
RENESAS
KIT, STARTER, SH7201
R5S72011B120FP
R0K572011S001BER0K572011S001BE
RENESAS
Starter Kit for SH7086
R5F70865AD80FPV
R0K570865S001BER0K570865S001BE
RENESAS
Starter Kit for SH7211
R5F72115D160FPV
R0K572115S001BER0K572115S001BE
SILICON LABORATORIES
DEVELOPMENT KIT, 16-BIT, 100TQFP
C8051F060, C8051F061, C8051F062 and more
C8051F060DKC8051F060DK
MICROCHIP
BOARD, DEV, 16BIT, NANOWATT XLP
DM240311DM240311
MICROCHIP
DEVELOPMENT BOARD KIT, 16-BIT, 28-PIN
PIC24
DM300027DM300027
FREESCALE SEMICONDUCTOR
16-BIT HCS12DT256 STUDENT LEARNING KIT
HCS12DT256
APS12DT256SLKAPS12DT256SLK
Evaluation Board for the 16-bit MC9S12XE and XS-Families
MC9S12XEP100
EVB9S12XEP100EVB9S12XEP100
16-bit HCS12 DG128 Learning Kit
MC9S12DG128CFUERMC9S12DG128CFUER
LFEBS12UBLABLFEBS12UBLAB
Document ListBack to Top
Datasheet
Part Number
Description
Size
R5F61622D50LGV
H8SX/1622 Group Hardware Manual
6256KB
REG99J0018-0200
Renesas Starter Kit for H8SX/1622 CPU Board Schematics
145KB
REG10J0075-0100
Renesas Starter Kit for H8SX/1622 Quick Start Guide
845KB
REG10J0074-0100
[E10A version] Renesas Starter Kit for H8SX/1622 Tutorial Manual
568KB
Application Notes
File Name
Size
0.18-μm Flash Memory Reprogramming in the User Boot Mode
325KB
0.18-μm Flash Memory Reprogramming in the User Program Mode
341KB
8-Bit Absolute Address Space Switching
54KB
Direct Operation on Values in Memory
172KB
Enhanced Addressing Mode (for Arrays)
184KB
Multiple-Bit Shifting
171KB
Short Format for Word/Longword-Sized Immediate Operands
173KB
H8SX Family Application Note BFLD Bit Field Transfer
124KB
H8SX Family Application Note BFST Bit Field Transfer
122KB
H8SX Family Application Note MOVMD.L Block Transfer Instruction
202KB
H8SX Family Application Note MOVSD Block Transfer Instruction
204KB
H8SX Family Application Note RTE/L Return from Exception Handling with Data Restoration
125KB
H8SX Family Application Note RTS/L Return from Subroutine with Data Restoration
123KB
Direct Memory Operation
450KB
Enhancement with the Bit-Manipulation Instruction
448KB
Short Address Access Switching
435KB
W/L Size Immediate Abbreviation
446KB
DMAC Normal Mode Transfer
74KB
Using a Timer-Generated Clock Signal to Drive SCI Transmission and Reception: DMAC Volume
232KB
Transfer of Longword Data to Odd AddressesDMAC Edition
89KB
Ring Buffer Processing Using Extended Repeat Area Function of the DMAC
191KB
Using the DMAC with Address Updating by Offset Addition
203KB
Using the Average Transfer Rate Generator in Transmission and Reception via the SCI (Serial Communications Interface): DMAC Volume
211KB
H8SX Family DTC Block Transfer Application Note
167KB
Transfer of Longword Data to Odd AddressesDTC Edition
111KB
DTC Transfer with Transfer Information Read Skipping Processing
204KB
Synchronous DRAM interface
148KB
Hardware & Software
File Name
Size
H8SX1622 Renesas Starter Kit Sample Code
47KB
H8, H8SX Family E10A-USB Emulator Application Note Flash Memory Download Program
281KB
E10A-USB Emulator HS0005KCU01H Application Note (Flash Memory Download Program)
372KB
E10A-USB Emulator HS0005KCU01H Application Note (Guide to Using Download Program to Flash Memory for E10A-USB)
50KB
ΔΣ A/D Converter User's Guide
331KB
ΔΣ AnalogDigital Conversion in Single Mode
213KB
A/D Conversion in Scan Mode
187KB
A/D Conversion Using Scan Mode
459KB
  • sp:renesas
  • at:evaluation_kit
  • at:tech_first_kit
