Embedded and Microcontrollers
Documents Tech First Kit-Renesas-R0K438099S000BE-EVK
  • Author Author: tech5
  • Date Created: 7 Jan 2010 5:08 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:54 AM
  • Views 616 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The Renesas Starter Kit for H8/36079 is intended as a user-friendly introductory and evaluation tool for the H8/36079 microcontroller. The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E8a emulator and/or Flash Development Toolkit.
The Renesas Starter Kit for H8/36079 may be connected to the host PC using a simple RS232 serial connection or via the included USB E8a on chip debugging interface.
The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools.
Kit Contents
  • CPU Board
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • E8a Emulator
  • Connection Cable (USB Cable, User Interface Cable)
  • Quick Start Guide
  • CD-ROM
    • Documents : User Manual, Tutorial, and more
    • IDE : High-performance Embedded Workshop
    • C/C++ Compiler: C/C++ Compiler Package for H8SX, H8S, H8 Families Evaluation Version
    • Debugger: E8a Emulator Debugger
    • Flash Programmer: Flash Development Toolkit Evaluation Version
Key FeaturesBack to Top
  • High-speed H8/300H central processing unit with the internal 16-bit architecture
    • Upward-compatible with H8/300 CPU on the object level
    • Sixteen 16-bit general registers
    • 62 basic instructions
  • Peripheral functions
    • RTC (can be used as a free running counter)
    • Timer B1 (8-bit timer)
    • Timer V (8-bit timer)
    • Timer Z (16-bit timer)
    • 14-bit PWM
    • Watchdog timer
    • SCI (asynchronous or clocked synchronous serial communication interface) × 2 channels
    • I2C bus Interface (conforms to the I2C bus interface format advocated by Philips Electronics)
    • 10-bit A/D converter
    • POR/LVD (Power-on reset and low-voltage detection circuits) (optional)
    • On-chip oscillator
Ordering InformationBack to Top
Supplier
Part Number
RENESAS
R0K436079S000BER0K436079S000BE
Associated Products
Supplier
Description
Support Device
Part Number
SWITCHCRAFT
DC Power Jack
JACK SOCKET, DC
RAPC712XRAPC712X
BOURNS
TRIMMER, 10K
potentiometer
3386F-1-103TLF3386F-1-103TLF
TYCO ELECTRONICS / AMP
PLUG, D, 40-40UNC, 9WAY
connector
3-338168-23-338168-2
Similar Products
SupplierDescriptionSupport DevicePart Number
RENESAS
Starter Kit for H8SX/1648F
R5F61648N50FPV
R0K561648S000BER0K561648S000BE
RENESAS
Starter Kit for H8SX/1664F
R5F61664N50FPV
R0K561664S001BER0K561664S001BE
RENESAS
Starter Kit for SH7124
R5F71242D50FP
R0K571242S001BER0K571242S001BE
RENESAS
KIT, STARTER, SH7201
R5S72011B120FP
R0K572011S001BER0K572011S001BE
RENESAS
Starter Kit for SH7086
R5F70865AD80FPV
R0K570865S001BER0K570865S001BE
RENESAS
Starter Kit for SH7211
R5F72115D160FPV
R0K572115S001BER0K572115S001BE
SILICON LABORATORIES
DEVELOPMENT KIT, 16-BIT, 100TQFP
C8051F060, C8051F061, C8051F062 and more
C8051F060DKC8051F060DK
MICROCHIP
BOARD, DEV, 16BIT, NANOWATT XLP
DM240311DM240311
MICROCHIP
DEVELOPMENT BOARD KIT, 16-BIT, 28-PIN
PIC24
DM300027DM300027
FREESCALE SEMICONDUCTOR
16-BIT HCS12DT256 STUDENT LEARNING KIT
HCS12DT256
APS12DT256SLKAPS12DT256SLK
Evaluation Board for the 16-bit MC9S12XE and XS-Families
MC9S12XEP100
EVB9S12XEP100EVB9S12XEP100
16-bit HCS12 DG128 Learning Kit
MC9S12DG128CFUERMC9S12DG128CFUER
LFEBS12UBLABLFEBS12UBLAB
Document ListBack to Top
Datasheet
Part Number
Description
Size
HD64F36079GFZ
H8/36079 Group H8/36077 Group Hardware Manual
6256KB
REG99J0019-0100
Renesas Starter Kit for H8/36079 CPU Board Schematics
87KB
REG10J0078-0100
Renesas Starter Kit for H8/36079 Quick Start Guide
235KB
REG10J0077-0100
Renesas Starter Kit for H8/36079 Tutorial Manual
248KB
Application Notes
File Name
Size
Self Test Sample Code for Renesas Microcontrollers
339KB
H8/300H Series On-Chip Supporting Modules Application Note
2026KB
Stepper Motor Using 1-2 Phase Excitation
759KB
Stepper Motor Using Two-Phase Excitation
773KB
Brush-Type DC Motor
590KB
Monitoring Software
3224KB
Transmission/Reception with Terminal Software (H8/3664)
1826KB
Transmission/Reception with Terminal Software (H8/3687)
1823KB
Control of a Brushless DC Motor (H8/3664)
131KB
Control of a Brushless DC Motor (H8/3687)
143KB
1-2 Phase Excitation Control for a Stepping Motor
141KB
Two-Phase Excitation Control for a Stepping Motor
153KB
Using Timer V Output to Drive a Buzzer
67KB
Hardware & Software
File Name
Size
Single Power Supply F-ZTAT On-Board Programming Application Note
1398KB
M3S-T2-Tiny: Ultracompact TCP/IP Protocol Stack Software
342KB
Compiler Package Application Note Call Walker
335KB
H8S H8/300 Series C/C++ Compiler Package Application Note
5449KB
HI Series RTOS Application Note
3076KB
M3S-TFS-Tiny: Original File System Software for Microcontrollers
428KB
H8/300H Tiny Series E8 Emulator Application Note Programming of On-Chip Flash Memory
1806KB
H8/300H Tiny Compact Emulator Operating Back Trace ([Trace] Window)
1141KB
H8/300H Tiny Compact Emulator Using GUI I/O Functions
987KB
E8 Emulator Application Notes Introductory Guide for H8/300H Tiny
1525KB
Flash Development Toolkit Application Note (Introduction)
2746KB
H836079 Renesas Starter Kit Sample Code
47KB
    • sp:renesas
    • at:evaluation_kit
    • at:tech_first_kit
