Embedded and Microcontrollers
Documents Tech First Kit-Renesas-R0K436079S000BE-EVK
  • Author Author: tech5
  • Date Created: 6 Jan 2010 12:37 PM Date Created
  • Last Updated Last Updated: 27 May 2012 12:54 AM
  • Views 750 views
  • Overview
  • Kit Contents
  • Ordering Information
Overview
The Renesas Starter Kit for H8/38099 is intended as a user-friendly introductory and evaluation tool for the H8/38099 microcontroller. The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E8a emulator and/or Flash Development Toolkit.
The Renesas Starter Kit for H8/38099 may be connected to the host PC using a simple RS232 serial connection or via the included USB E8a on chip debugging interface.
The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools.
Kit Contents
  • CPU Board
  • Detachable AD Adjustment Shaft
  • E8a Emulator
  • E10A-USB for Starter Kit
  • Connection Cable (USB Cable, User Interface Cable)
  • Quick Start Guide
  • CD-ROM
  • CD-ROM
    • Documents : User Manual, Tutorial, and more
    • IDE : High-performance Embedded Workshop
    • C/C++ Compiler : C/C++ Compiler Package for H8SX, H8S,H8 Families Evaluation Version
    • Debugger : E8a Emulator Debugger
    • Flash Memory Programmer : Flash Development Toolkit Evaluation Version
Ordering InformationBack to Top
Supplier
Part Number
RENESAS
R0K438099S000BER0K438099S000BE
Associated Products
Supplier
Description
Support Device
Part Number
SWITCHCRAFT
DC Power Jack
JACK SOCKET, DC
RAPC712XRAPC712X
BOURNS
TRIMMER, 10K
potentiometer
3386F-1-103TLF3386F-1-103TLF
TYCO ELECTRONICS / AMP
PLUG, D, 40-40UNC, 9WAY
connector
3-338168-23-338168-2
Similar Products
SupplierDescriptionSupport DevicePart Number
RENESAS
Starter Kit for, H8/36079
HD64F36079GFZ
R0K436079S000BER0K436079S000BE
RENESAS
Starter Kit for H8SX/1648F
R5F61648N50FPV
R0K561648S000BER0K561648S000BE
RENESAS
Starter Kit for H8SX/1664F
R5F61664N50FPV
R0K561664S001BER0K561664S001BE
RENESAS
R5F71242D50FP
R0K571242S001BER0K571242S001BE
RENESAS
KIT, STARTER, SH7201
R5S72011B120FP
R0K572011S001BER0K572011S001BE
RENESAS
Starter Kit for SH7086
R5F70865AD80FPV
R0K570865S001BER0K570865S001BE
RENESAS
Starter Kit for SH7211
R5F72115D160FPV
R0K572115S001BER0K572115S001BE
SILICON LABORATORIES
DEVELOPMENT KIT, 16-BIT, 100TQFP
C8051F060, C8051F061, C8051F062 and more
C8051F060DKC8051F060DK
MICROCHIP
BOARD, DEV, 16BIT, NANOWATT XLP
DM240311DM240311
MICROCHIP
DEVELOPMENT BOARD KIT, 16-BIT, 28-PIN
PIC24
DM300027DM300027
FREESCALE SEMICONDUCTOR
16-BIT HCS12DT256 STUDENT LEARNING KIT
HCS12DT256
APS12DT256SLKAPS12DT256SLK
Evaluation Board for the 16-bit MC9S12XE and XS-Families
MC9S12XEP100
EVB9S12XEP100EVB9S12XEP100
16-bit HCS12 DG128 Learning Kit
MC9S12DG128CFUERMC9S12DG128CFUER
LFEBS12UBLABLFEBS12UBLAB
Document ListBack to Top
Datasheet
Part Number
Description
Size
HD64F38099FP
H8/38099 Group Hardware Manual
5212KB
RJJ99J0035-0010
Renesas Starter Kit for H8/38099 CPU Board Schematics
81KB
REJ10J1531-0100
Renesas Starter Kit for H8/38099 Quick Start Guide
194KB
REJ10J1530-0100
Renesas Starter Kit for H8/38099 Tutorial Manual
231KB
Application Notes
File Name
Size
H8/300H Series On-Chip Supporting Modules Application Note
2026KB
Compiler Package Application Note Call Walker
335KB
H8S H8/300 Series C/C++ Compiler Package Application Note
5449KB
HI Series RTOS Application Note
3076KB
Flash Development Toolkit Application Note (Introduction)
2746KB
H8/300H Tiny Series E8 Emulator Application Note Programming of On-Chip Flash Memory
1806KB
Differences between Normal and Advanced Modes in Programming Method on Super Low Power Microcontrollers
663KB
Example of Driving an MCU from a Low-Voltage Power Supply by Using a Step-Up DC/DC Converter and Start-Up IC
78KB
Sensor Connection with Low Supply Current Using Comparator and A/D Converter
163KB
Setting the Waiting Time to Cover Clock Stabilization (Timing of Reset Release and Setting of Wait States)
80KB
H8/300H SLP Series Application Note Address Break
173KB
H8/300H SLP Series Application Note Clock Output Using RTC Clock Output Function
153KB
Hardware & Software
File Name
Size
H838099 Renesas Starter Kit Sample Code
47KB
M3S-TFS-Tiny: Original File System Software for Microcontrollers
428KB
H8/300H Tiny Compact Emulator Operating Back Trace ([Trace] Window)
1141KB
H8/300H Tiny Compact Emulator Using GUI I/O Functions
987KB
E8 Emulator Application Notes Introductory Guide for H8/300H Tiny
1525KB
2746KB
  • sp:renesas
  • at:evaluation_kit
  • at:tech_first_kit
