Embedded and Microcontrollers
Documents Tech First Kit-OLIMEX-SAM9-L9260-MCU-Dev Kit
  • Author Author: tech5
  • Date Created: 8 Jan 2010 6:29 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:54 AM
  • Views 651 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
SAM9-L9260 is a low cost development platform with ARM9 microcontroller, 64MB SDRAM and 512MB NAND Flash. The board has Ethernet 100Mbit controller, USB host, USB device, RS232 and 40 pin extension port with all unused SAM9260 ports available for add-on boards. SAM9-L9260 has waste amount of Flash and RAM and runs Linux, WindowsCE and other RTOS natively. The on-board RTC clock is equipped with a 3V Li backup battery.
Kit Contents
  • SAM9-L9260 Development board
  • AT91SAM9260 microcontroller
Key FeaturesBack to Top
  • MCU: AT91SAM9260 16/32 bit ARM9Tm 180MHz operation
  • Standard JTAG connector with ARM 2x10 pin layout for programming/debugging with ARM-JTAG
  • 64 MB SDRAM
  • 512MB NAND Flash (seen in Linux as silicon drive)
  • Ethernet 100Mbit connector
  • USB host and USB device connectors
  • RS232 interface and drivers
  • SD/MMC card connector
  • One user button and one reset button
  • One power and two status LEDs
  • On board voltage regulator 3.3V with up to 800mA current
  • Single power supply: 5V DC required
  • Power supply filtering capacitor
  • 18.432 Mhz crystal on socket
  • Extension header
  • PCB: FR-4, 1.5 mm (0,062"), soldermask, silkscreen component print
  • Dimensions: 100 x 80 mm (3.94 x 3.15")
      Ordering InformationBack to Top
      Supplier
      Part Number
      OLIMEX
      SAM9-L9260SAM9-L9260
      Associated Products
      Supplier
      Description
      Part Number
      ATMEL
      MCU, 32BIT, ARM9, 8K SRAM, 217CBGA
      AT91SAM9260AT91SAM9260
      MICRON
      SDRAM 64MB, SMD, 48LC4, TSOP54
      MT48LC4M16A2P-7E:G:GMT48LC4M16A2P-7E:G:G
      NUMONYX
      FLASH NAND 512MB, SMD, TSOP48, 512
      NAND512W3A2CN6ENAND512W3A2CN6E
      Similar Products
      SupplierDescriptionSupport DevicePart Number
      OLIMEX
      BOARD, DEV, FOR AT91SAM9260 W/TOUCH-TFT
      AT91SAM9260
      ATMEL
      AT91SAM9260
      AT91SAM9260-EKAT91SAM9260-EK
      Document ListBack to Top
      Datasheet
      Part Number
      Description
      Size
      SAM9-L9260
      SAM9-L9260.pdf users manual
      910KB
      Application Notes
      File Name
      Size
      Analog-to-Digital Converter in the AT91M55800A
      153KB
      AT91RM9200 Microcontroller Schematic Check List
      122KB
      AT91-AN02: Signal Integrity and AT91 Products
      71.3KB
      Hardware & Software
      File Name
      Size
      SAM9-L9260 schematic
      64KB
      SAM9-L9260 REV.B schematic
      63.7KB
      linux-2.31-rc8-olimex-patches.zip Linux kernel patches for SAM9
      153KB
      u-boot-olimex-patches-20090717.tgz U
      122KB
      nanx-sam9-l9260.zip NanoX 1.0 patch for SAM9
      71.3KB
      SAM9-L9260 test code for EW
      1.5MB
      Other Resources
      File Name
      Size
      Stock linux 2.6.23 kernel
      41.7KB
      Full list of supported peripherals
      5KB
    • at:development_kit
    • ap:mcu
    • sp:olimex
    • at:tech_first_kit
