Embedded and Microcontrollers
Documents Tech First Kit-Olimex-PIC-P40-20MHz-EVK
  • Author Author: tech5
  • Date Created: 7 Jan 2010 8:03 AM Date Created
  • Last Updated Last Updated: 27 Oct 2013 2:25 AM
  • Views 616 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
With this board you can develop and prototype with any of Microchip's 40 pin PIC microcontrollers. The RS232 driver on board allows easy connection with PC or other embedded hardware. The board have User button and status LED. The bridge rectifire allow this board to be powered with both AC and DC power supply adapters. PIC-P40 supports both 3V low power and normal 5V operation.
Kit Contents
  • RS232
  • ICSP connector
  • Three Jumper
    • +3/+5 volt Jumper
    • LED Jumper
    • DTR/RTS Jumper
Key FeaturesBack to Top
  • ICSP/ICD connector for programming with PIC-MCP-USB, PIC-MCP or PIC-PG1, PIC-PG2, PIC-PG3, PIC-PG4 and debugging with PIC-ICD2, PIC-ICD2-POCKET, PIC-ICD2-TINY(* for the PICs with ICD support) for PIC16F87X is possible to debug with the low cost PIC-ICD1.
  • RS232 Tx, Rx interface with MAX232 IC on socket
  • DIL40 microcontroller socket
  • Quartz crystall 20Mhz
  • LED to RA0 through jumper
  • User Button on RE2 port
  • Reset button
  • Power plug-in jack
  • Selectable +3.3V / +5V power supply voltage regulator
  • Extension slot on every uC pin
  • Gird 100 mils
  • GND bus
  • Vcc bus
  • Four mounting holes 3,3 mm (0,13")
  • FR-4, 1.5 mm (0,062"), green soldermask, white silkscreen component print
  • Dimensions 100x80 mm (3,9x3,15")
    Ordering InformationBack to Top
    Supplier
    Part Number
    OLIMEX
    PIC-P40-20MHZPIC-P40-20MHZ
    Associated Products
    Supplier
    Description
    Support Device
    Part Number
    MICROCHIP
    8BIT FLASH MCU, 16F876, SDIL28
    16F876
    PIC16F876-20I/SPPIC16F876-20I/SP
    MAXIM INTEGRATED PRODUCTS
    Transceiver IC
    RS232
    MAX232ACPE+MAX232ACPE+
    TYCO ELECTRONICS / AMP
    PLUG, D, 40-40UNC, 9WAY
    RS232 DB9_male
    3-338168-23-338168-2
    Similar Products
    SupplierDescriptionSupport DevicePart Number
    MICROCHIP
    SIGNAL ANALYSIS BOARD KIT, PICKIT
    PIC16F684, 25LC640
    AC164120AC164120
    Microchip
    DEVELOPMENT KIT, LOW PIN COUNT
    PIC16F690
    DM164120-1DM164120-1
    Microchip
    KIT, PICKIT 2 28-PIN DEMO BOARD
    PICkit 2 28-Pin Demo Board
    DM164120-3DM164120-3
    Microchip
    PICkit Serial Analyzer
    PIC16F886
    DV164122DV164122
    Microchip
    DEBUG KIT, EXPRESS, PICKIT2
    PIC12F5xx, PIC12F6xx, PIC16F5xx
    DV164121DV164121
    Document ListBack to Top
    Datasheet
    Part Number
    Description
    Size
    PIC16F876
    PIC16F873/4/6/7 Datasheet
    3.73MB
    Application Notes
    File Name
    Size
    AN1066 - MiWi Wireless Networking Protocol Stack
    634KB
    AN1229 - Class B Safety Software Library for PIC MCUs and dsPIC DSCs
    399KB
    ADN004 Ease into the Flexible CANbus Network
    151KB
    Hardware & Software
    File Name
    Size
    PIC-P28 schematic
    24KB
    PIC ICSP connector
    2.7KB
    Blink LED demo code
    17.3KB
    Botton read demo code
    17.1KB
    RS232 demo code
    18.3KB
    AN1229 Source Code
    342KB
    • at:evaluation_kit
    • sp:olimex
    • at:tech_first_kit
