Embedded and Microcontrollers
Documents Tech First Kit-Olimex-LPC-2378STK-ARM-DVB
  • Author Author: tech2
  • Date Created: 8 Jan 2010 3:53 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:54 AM
  • Views 788 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
Development prototype board with LPC2378FBD144,551LPC2378FBD144,551 Ethernet, USB, 2x CAN, 2xRS232, Ethernet, SD/MMC, Audio in-out
Kit Contents
The software below is available for all of our customers who purchase the development board:
  • LPC-2738STK Board
  • Software is available for customers who purchase the development board
Key FeaturesBack to Top
The EK-LM3S811 expansion board has the following features:
  • MCU: LPC2378FBD144,551LPC2378FBD144,551 16/32 bit ARM7TDMI-STmt with 512K Bytes Program Flash, 16K Bytes RAM, EXTERNAL MEMORY BUS, RTC, 4x 10 bit ADC 2.44 uS, 2x UARTs, 4x CAN, I2C, SPI, 2x 32bit TIMERS, 7x CCR, 6x PWM, WDT, 5V tolerant I/O, up to 60MHz operation
  • standard JTAG connector with ARM 2x10 pin layout for programming/debugging with ARM-JTAG
  • Optional - TRACE connector
  • 128x128 pixel 12 bit color TFT LCD with backlight
  • Ethernet 100MBit
  • MMA7620 3 axis accelerometer
  • Two RS232 port
  • Two CAN drivers and connector
  • SD/MMC card connector
  • UEXT connector with I2C, SPI, RS232 and power supply for connecting add-on modules like RF link, MP3, etc available from Olimex
  • IrDA transciever on board
  • Audio in and Audio Out jacks for microphone and headphones
  • trimpot connected to ADC
  • RESET circuit with external control of Philips ISP utility via RS232 port
  • Jumpers for ISP/RUN mode
  • Joystick with four directions and push action
  • two USER button
  • RESET Button
  • two on board voltage regulators 3V and 5V with up to 800mA current
  • Extension port connector for many of microcontrollers pins
  • single power supply: External power supply, USB or JTAG connector
  • Battery holder and connector for the RTC
  • power supply led
  • FR-4, 1.5 mm, red soldermask, component print
  • Dimensions: 135x101mm (5.3x3.98")
Ordering InformationBack to Top
Supplier
Part Number
Olimex
LPC2378-STKLPC2378-STK
Associated Products
Supplier
Description
Part Number
NXP
MCU 32bit ARM7 with 10/100 Ethernet, USB, CAN
LPC2378FBD144LPC2378FBD144
Micrel
3.3V 10/100Base Physical Layer Transceiver
KSZ8721BLKSZ8721BL
Maxim
Low-Power, up to 1Mbps, True RS-232RS-232 Transceivers
MAX3232CDBMAX3232CDB
Freescale
3-Axis Acceleration Sensor
MMA7260QTMMA7260QT
Microchip
Hi Speed CAN Transceiver
MCP2551-I/PMCP2551-I/P
Similar Products
SupplierDescriptionSupport DevicePart Number
Olimex
DEVELOPMENT BOARD WITH USB, 4x CAN, RS232, ETHERNET
LPC2294
LPC-E2294-1MBLPC-E2294-1MB
Olimex
uC Linux Development Board with LPC2468 USB,Ethernet,SD/MMC IN CREDIT CARD FORMAT
LPC2468
LPC-E2468LPC-E2468
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
260KB
KSZ8721BL
62KB
MAX3232CDBRMAX3232CDBR
Low-Power, up to 1Mbps, True RS-232 Transceivers
760KB
MMA7260QT
194KB
MCP2551-I/P
263KB
Application Notes
File Name
Size
AN228 - A CAN Physical Layer Discussion
258.8KB
AN713 - An introduction to the CAN protocol that discusses the basics and key features.
141.6KB
DG9 - Analog Solutions for Automotive Applications Design Guide
284.7KB
ADN004 Ease into the Flexible CANbus Network
151.0KB
NicheLite for LPC implementation notes
190.2KB
NXP LPC2000 CAN driver with FullCAN mode
729.2KB
AN3107 Measuring Tilt with Low-g Accelerometers
320.4KB
g-Sensor Brake Lamp Demonstration video
AN3751, Frequency Analysis in the Industrial Market Using Accelerometer Sensors
752.3KB
AN3151, Detecting Freefall with Low-G Accelerometers
569.5KB
Application Note 723: Selecting and Using RS-232, RS-422, and RS-485 Serial Data Standards
102KB
Application Note 3424: RS-232 Powered Temperature Sensor
43kB
Hardware & Software
File Name
Size
LPC2378STK schematic
105KB
  • ap:arm
  • at:development_board
  • sp:olimex
  • at:tech_first_kit
