Embedded and Microcontrollers
Documents Tech First Kit-OLIMEX-SAM7-P256-MCU-Dev Kit
  • Author Author: tech5
  • Date Created: 7 Jan 2010 11:59 AM Date Created
  • Last Updated Last Updated: 6 Apr 2010 6:34 AM
  • Views 734 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
SAM7-P256 development board is designed for AT91SAM7S256 ARM7TDMI-S microcontroller.
Kit Contents
  • SAM7-P256 Development board
  • AT91SAM7S256 microcontroller
Key FeaturesBack to Top
  • MCU: AT91SAM7S256 16/32 bit ARM7TDMITm with 256K Bytes Program Flash, 64K Bytes RAM, USB 2.0, RTT, 10 bit ADC 384 ksps, 2x UARTs, TWI (I2C), SPI, 3x 32bit TIMERS, 4x PWM, SSC, WDT, PDC (DMA) for all peripherals, up to 60MHz operation
  • Standard JTAG connector with ARM 2x10 pin layout for programming/debugging with ARM-JTAG
  • USB connector
  • Two channel RS232 interface and drivers
  • SD/MMC card connector
  • Two buttons
  • Trimpot connected to ADC
  • Thermistor connected to ADC
  • Two status LEDs
  • On board voltage regulator 3.3V with up to 800mA current
  • Single power supply: 6V AC or DC required
  • Power supply LED
  • Power supply filtering capacitor
  • RESET circuit
  • RESET button
  • 18.432 Mhz crystal on socket
  • Extension headers for all uC ports
  • PCB: FR-4, 1.5 mm (0,062"), soldermask, silkscreen component print
  • Dimensions: 120 x 80 mm (4.7 x 3.15")
Ordering InformationBack to Top
Supplier
Part Number
OLIMEX
SAM7-P256SAM7-P256
Associated Products
Supplier
Description
Part Number
OLIMEX
TFT LCD, 4096 colors, backlight
MOD- NOKIA6610MOD- NOKIA6610
Similar Products
SupplierDescriptionPart Number
OLIMEX
KIT, DEV, ATMEL ARM7TDMI BOARD
SAM7-EX256SAM7-EX256
AND Display
NTSC, PAL, TFT Analog VGA; Display Mode
AND-TFT-35VX-KITAND-TFT-35VX-KIT
Document ListBack to Top
Datasheet
Part Number
Description
Size
SAM7-P256
SAM7-P256.chm
410KB
Application Notes
File Name
Size
How to program SAM7-P256
12MB
Using Open Source Tools for AT91SAM7 Cross Development - Revision B
6KB
Hardware & Software
File Name
Size
SAM7-P256 blinking LED project and binary code for SAM-BA load
609KB
SAM7-P256 sample mouse driver project
1.14MB
UART routines project
85KB
SD/MMC read/write routines project
95KB
Button read, temperature measurement project
109KB
MOD-SMB380 read demo code for EW-ARM 4.11 with SAM7-P64/256 board
919KB
USB virtual COM port for GCC+OpenOCD+Eclipse
279KB
OpenOCD + Eclipse set of projects 1.00 include flash write make file for SAM7-P256
2.78MB
SAM7-P256 schematic REV.E
385KB
Other Resources
File Name
Size
The complete list of projects
63.7KB
  • at:development_kit
  • ap:mcu
  • sp:olimex
  • at:tech_first_kit
