Embedded and Microcontrollers
Documents Tech First Kit-OLIMEX-TMS320-P28016-MCU-Dev Kit
  • Author Author: tech5
  • Date Created: 8 Jan 2010 4:29 AM Date Created
  • Last Updated Last Updated: 6 Apr 2010 6:35 AM
  • Views 986 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
TMS320F28016 is known to be the world's lowest cost 32-bit Real Time Microcontroller (DSP) with build in CAN and cost only US $3.60 / 1000 pcs quantity. This is very good bargain for 32-bit core running at 60 Mhz, delivering 60 MMACS, 32KB Flash, 12 KB RAM, 8 channel PWM 6 of them with enhanced resolution of 150 ps(!), 2 x 8 channels 3.75 MPSP 12-bit ADCs, CAN, RS232, SPI, I2C.
Kit Contents
  • TMS320F28016 development board
  • TMS320F28016 microcontroller
    Key FeaturesBack to Top
    • MCU: TMS320F28016 32KB Flash, 12 KB RAM, 3.75 MPSP 2 x 8 channel ADCs, 8 PWM, CAN, SPI, RS232, I2C
    • JTAG connector
    • USB-to-RS232 convertor allow easy to power board and to connect to notebooks and decent computers without RS232 port
    • CAN driver and connector
    • UEXT connector with SPI, RS232, I2C for connection to other Olimex modules as MOD-NRF24Lx, MOD-MP3, etc
    • MOTOR control connector (for add on modules with ADC, PWM, Interrupt signals available)
    • User button
    • Trimmer potentiometer connected to Analog input
    • Power supply LED
    • User status LED
    • RST button
    • External power supply jack for AC or DC power supply
    • Voltage regulator + power supply filtering capacitor
    • Extension headers for each uC pin
    • Prototype area with 0.1" step, Vcc + GND bus
    • PCB: FR-4, 1.5 mm (0,062"), green soldermask, white silkscreen component print
    • Dimensions: 100x80 mm (3.9x3.15")
          Ordering InformationBack to Top
          Supplier
          Part Number
          OLIMEX
          TMS320-P28016TMS320-P28016
          Associated Products
          Supplier
          Description
          Part Number
          Texas Instruments
          DSP, C2000, 16K X 16 FLASH, LQFP100
          TMS320F28016PZQTMS320F28016PZQ
          ROTH
          SMT Device Adapter. SMD, FR4, 24-144PIN
          RE471RE471
          Similar Products
          SupplierDescriptionSupport DevicePart Number
          Texas Instruments
          KIT, STARTER, EZ-DSP, F2812
          TMS320F28016
          TMDSEZD2812TMDSEZD2812
          Document ListBack to Top
          Datasheet
          Part Number
          Description
          Size
          TMS320-P28016
          TMS320-P28016 users manual
          910KB
          Application Notes
          File Name
          Size
          Code Composer Studio tutorial how to use TMS320-P28016 board
          153KB
          Flash programming on TMS320-P28016
          574KB
          Running an Application from Internal Flash Memory on the TMS320F28xx DSP (Rev. H)
          153KB
          Spread-Frequency Shift Keying Power Line Modem Software Architecture
          122KB
          Using Enhanced Pulse Width Modulator (ePWM) Module for 0-100% Duty Cycle Control
          71.3KB
          Flash Programming Solutions for the TMS320F28xxx DSCs
          1.5MB
          Optimizing Digital Motor Control Libraries
          72.9KB
          Configuring the TMS320F280x DSP as an I2C Processor
          375KB
          Interfacing SD/MMC Cards With TMS320F28xxx DSCs
          256KB
          Hardware & Software
          File Name
          Size
          TMS320-P28016 Rev. A schematic
          64KB
          Blink LED C Source and CCS project files
          63.7KB
          RS232 echo back C Source and CCS project files
          153KB
          ADC read C source and CCS project files
          122KB
          Flash programming blink LED
          71.3KB
        • at:development_kit
        • ap:mcu
        • sp:olimex
        • at:tech_first_kit
