Hello I have a Gameboy advance sp that I'm turning into a mini arcade cabinet but I'd like a larger display for it it comes standard with a 2.9 inch tft display and it's ribbon cable that connects to the main board is 34 pins I do not know the pitch of the pins but I'd like to upgrade it to a 4.3 inch tft display if said lcd had the same pin # and pitch and readily fit in the zif connector would it work if the operating voltage is 3.7 v
