Ask an Expert Forum transistor trouble
  • Subscribers 316 subscribers
  • Views 918 views
See a helpful answer?
transistor trouble
jasonshader
jasonshader over 6 years ago
Hello element 14, I am beginning to learn how to build simple circuits with leds and tried using a transistor and having problems. My leds are lighting up without a base current at all as soon as I connect collector and emitter. Any ideas on what im doing wrong?
  • fmilburn
    fmilburn over 6 years ago +3
    Hi Jason, there are a number of things that could cause this including not having the circuit wired as you intended. A circuit diagram and a photo would help. Things like whether you are trying to use…
  • colporteur
    colporteur over 6 years ago +1
    Jason you have some to the right place for help. There are some real bright and talent people that frequent this site, who are willing to not only troubleshoot your problem but give you the knowledge to…
  • fmilburn
    Hi Jason,
    there are a number of things that could cause this including not having the circuit wired as you intended.  A circuit diagram and a photo would help.  Things like whether you are trying to use the transistor as a constant current source or as a switch are important.  What is the power source, type of transistor, etc.
    Frank
  • colporteur
    Jason you have some to the right place for help. There are some real bright and talent people that frequent this site, who are willing to not only troubleshoot your problem but give you the knowledge to understand. One of the keys to getting that answer is providing sufficient information. As was suggested by fmilburn a drawing or in technical terms a schematic of your circuit will help people zero in on the answer.
    You could hand draw a schematic and take a picture to post or use a number of graphics programs to generate the drawing. KCad and Fritzing are two that are for electronic design that come to mind. I work primarily with Linux. It looks like Fritzing has a MS Windows install.
    Before you get discouraged stop and think. The schematic software that you may have to learn, is just one more tool that will help you explore electronic. It makes it easy to document what you are doing.
    dougw over 6 years ago
    If you connect the LED to the base instead of the collector, the LED may light up, but it probably isn't good for the transistor.
    michaelkellett over 6 years ago
    Like the others said  - show us a diagram or a photo !
    (and maybe tell us what you want to happen in the circuit)
