Ask an Expert Forum Re: Stuck on Experiment 11: Make Electronics
  • Subscribers 304 subscribers
  • Views 1060 views
See a helpful answer?
opalko
opalko over 5 years ago
jc2048  wrote:
Can I use polarized 3.3uF caps in this experiment?
Positive to collector, negative to the base of the opposing transistor.
Transistors: The Astable Multivibrator (Featuring SuperLEDman).
So, does it matter as long as both capacitors are oriented the same way?
    shabaz over 5 years ago +2
    Hi Robert, You should try it, and see what happens. If you don't have 10uF capacitors then three 3.3uF capacitors in parallel equals approx 10 uF. So, you could try just 3.3uF, observe the effect, and…
  • jc2048
    jc2048 over 5 years ago +2
    Sorry, I wasn't very clear. Yes, you can use a polarized capacitor. Just be sure to get the orientation right or you'll damage it. I gave the link to the blog so that you could see how I'd wired the electrolytics…
    Hi Robert,
    You should try it, and see what happens. If you don't have 10uF capacitors then three 3.3uF capacitors in parallel equals approx 10 uF. So, you could try just 3.3uF, observe the effect, and then add another in parallel to make 6.6uF, see what happens, and then try another, to combine to 9.9uF.
  • jc2048
    Sorry, I wasn't very clear. Yes, you can use a polarized capacitor. Just be sure to get the orientation right or you'll damage it. I gave the link to the blog so that you could see how I'd wired the electrolytics when I used the same circuit, in case you weren't sure from my words.
    As well as experimenting with the capacitor value, as Shabaz suggests, you could also try experimenting with the resistors that go from the base end of the capacitor to the supply. Don't go too wild, but maybe double the value and see what effect it has.
