Hi folks, as my previous posts indicate, I am new to this stuff.
I bought a Siglent SDS1202X-E when it was on sale and have been trying to teach myself the basics of it (probably not very well).
As it is, I have an old Atari 810 disk drive (Tandon) that is not working and one of the things I keep hearing is to test the drive speed. The field service manual for the drive says:
Set Frequency Counter Controls to the following settings:
A. 10k Resolution or 1 Second Sample Time
B. X1 attenuation or Maximum sensitivity
C. X1 Probe (preferred)
When the frequency counter is properly adjusted, a 60.2 KHz reading should be seen on counter.
I guess the first question I should be asking is can I even use this scope to measure this?...
If I can, and I don't know if I am doing it correctly, I get what looks like varying frequency results without even adjusting the potentiometer that controls the drive speed. When I hook everything up and hit "Measure", I get varying readings for the frequency as seen in screenshots below. So,
- I am not doing something correctly with the scope (most likely) and/or
- I can't really use this scope to measure what needs to be measured (also likely) or
- the wild readings mean the potentiometer or something else is bad?
I will reiterate I am very new to this....
Thanks for any guidance on using this scope or repairing this drive...!
