Ask an Expert Forum Leaving me breathless - analysing your exhalation
  • Replies 11 replies
  • Subscribers 315 subscribers
  • Views 1753 views
  • breathe
  • exhalation
  • exhale
  • sensor
  • air sensor
See a helpful answer?
cstanton
cstanton over 4 years ago
For medical reasons, I'm interested in measuring the following, with the ability to capture the data and plot it over time from the air that you exhale / breathe out:
- hydrogen sulfide
- nitric oxide
I would be tempted to also say that heart rate would be nice at this point as well, but that can be pulled from other devices that somewhat do it better (eg. fitbit - though it'd be nice to plot the data against one another..)
I don't know what sensors I'd use for this or where to start looking?
    Jan Cumps over 4 years ago +4
    Here's a small device that does that: https://www.rkiinstruments.com/product/portable-gas-detector/ They measure : Combustible Gases (Methane as standard) Oxygen (O2) Hydrogen Sulfide (H2S) Carbon Monoxide…
  • Gough Lui
    Gough Lui over 4 years ago +1
    Perhaps there are MOX-based gas sensors that could detect them, but I wouldn't necessarily trust them to be all that selective as cross-sensitivity is a known issue. Because these operate on a hotplate…
    Jan Cumps over 4 years ago in reply to Jan Cumps +1
    I checked the price. It's around $ 500. As an alternative, we can check with Randall if a combination of these sensors would be up for a road test. Or maybe a design challenge?
  • Gough Lui
    Perhaps there are MOX-based gas sensors that could detect them, but I wouldn't necessarily trust them to be all that selective as cross-sensitivity is a known issue. Because these operate on a hotplate principle, their peak current consumption and size could be problematic.
    - Gough
    They measure :
    Oxygen (O2)
    Carbon Monoxide (CO)
  • cstanton
    cstanton over 4 years ago in reply to Jan Cumps
    Mmm, doesn't appear to do NO (Nitric Oxide) ?
    Jan Cumps over 4 years ago in reply to cstanton
    No. It can either do one of these combinations:
    CH4, O2, NO2 (natrium dioxide) & CO or
    CH4, O2, H2S & CO
    Design Contest Time!
    (contenders would need to have access to characterised samples of the gasses though)
  • javagoza
    javagoza over 4 years ago
    I am very interested in your question, it has piqued my curiosity.
    The first thing I have found is this NIOX VERO device
    https://www.niox.com/
    you may already know it.
    It may provide a hint about possible sensors. It doesn't seem like an easy task for a portable device.
    https://www.niox.com/en-cn/pdf/000247-08%20NIOX%20VERO%20Labeling%20summary%20EU.pdf
    https://patentimages.storage.googleapis.com/cc/ba/05/34cc530da8549f/US10130284.pdf
    https://patentimages.storage.googleapis.com/34/d3/8a/17634c08a84d00/US20110314896A1.pdf
    michaelkellett over 4 years ago
    The reference from javagoza is pretty useful.
    Worth reading the operating manual which will give you an idea of just how difficult this is.
    The usual sources sell NO sensors (eg Alphasense) but their parts have a 25 s response time which will be much too slow.
    This is a good paper that talks about laser based mid IR detectors - good, fast but certainly not cheap.
    https://coe.ou.edu/sserg/web/Publication/Papers/Nitric%20Oxide%20Breath%20Testing%20Using%20Tunable%20Diode%20Laser%20Ab…
    What are you trying to make ?
  • cstanton
    cstanton over 4 years ago in reply to javagoza
    Thanks, I was not aware of the Niox, it looks like it's been assessed by NICE as well. Good thing I don't plan on making a device for the purpose of selling it.
  • cstanton
    cstanton over 4 years ago in reply to michaelkellett
    michaelkellett
    Could you explain what you mean?
    Aha, spectroscopy, that was a term that I kept grasping for when I was thinking about this. Thanks for the article.
    michaelkellett over 4 years ago in reply to cstanton
    Chemical sensors like the Alphasense have a time constant measured in seconds (25 in their case).
    So a single breath won't be enough to get a good result.
    Ideally for measuring exhalation gas you need to be able to make many measurements per breath.
    So you need a sensor with a time constant more like 25ms - or tricky means of gas capture and storage while the sensor responds.
