Ask an Expert Forum Does a burned/charred FR-4 type board conduct electricity?
  • Subscribers 315 subscribers
  • Views 1153 views
  • board
  • charred
  • burned
  • ciruit
  • pcb
  • soot
  • burnt
See a helpful answer?
Former Member over 15 years ago
I am doing a repair on a guitar tube amp.  The circuit board has some burned up traces so I'm planning on re-routing around the bad traces with stranded wire.  I have heard that I need to grind away all the black soot because it will conduct electricity.  Is this true?
Thanks!
  • mberman
    mberman over 15 years ago
    Hi Duane,
    It would be best to scrape away and clean the charred (soot) areas of the pc board a bit because "carbon" is a conductor.  Also, make sure you use stranded wire with the proper current and voltage ratings for the repair.  Vacuum Tubes operate off high voltages as you may know.
    Mel
