Ask an Expert Forum Power Supply for Home lab?
  • Replies 136 replies
  • Subscribers 345 subscribers
  • Views 20579 views
  • diy_power_supply
  • function_generator
  • power_supplies
  • diy
  • voltage/current
  • power_supply
  • power_meter
  • variable_power_supply
See a helpful answer?
mudz
mudz over 10 years ago
I am starting this year with different projects. Indeed, I need a power supply which I felt for so long is the main missing component in my small home lab. Currently, I am using PC SMPS, Transformers, and different adaptors to power up different projects and kits.
Many times I felt need of a variable power source but I did that with two different power supplies, but it is time consuming. And many more things to say but its just a waste of time to write and for yourself to read...... Now Its too much and I'm going to build one good power supply. Previously I'm fulfilling my power supply needs by using a adaptor and then using a voltage regulator(7805, 7809, 7812, LM317..) afterward for my projects.
So, what do you suggest?
Also I'm going to include few more additions to it like function generator, power consumption meter.
So what do you suggest what will be the best thing to make a good power supply?
An IC?
A Microcontroller? like PIC
Just build a box consisting a transformer/adaptor with voltage regulator and few pots?
Do tell me which will be better to use? A microcontroller or IC available in market for specific task for example Function generator IC? I'm confused should I go with a microcontroller and make my own program to do these tasks or should I buy an IC for individual task and then using a controller to control all?
mudz
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago +3
    I know this is self promoting but I am in the middle of a set of tutorials on building a LAB / Bench power supply and accessories I start with the basic building blocks, explaining in practical terms what…
    michaelkellett over 10 years ago +2
    There is no best - it depends what you are doing - I have loads of different power supplies (it's my work not just a hobby so they can be paid for if needed.) My favorite general purpose supply is a rather…
    Robert Peter Oakes over 10 years ago in reply to mudz +2
    I would suggest starting with a basic naalog design (As I have shown in my series), understand its operation, then it should be a simple extension to add DAC and ADC monitoring this way it seperates the…
    michaelkellett over 10 years ago in reply to mudz
    I think everyone goes through a stage of looking at stuff on the  market and thinking that they can do it cheaper - but never assume that those guys at HP/Agilent/Keysight or Keithley or even Tenma (E14's cheapo Chinese brand)  or where ever are dumb.
    For starters - unless you want to make zillions of things you don't want to be at the cheap end of the market - because you can't make any money selling just a few things with a low margin.
    And if you want to play at the high end you need to offer something good:
    Just for fun compare the specs/prices of Rigol's DP832A with the AimTTi MX180TP(E14 sell the  MX180TPMX180TP easy to find Rigol specs and prices on the web
    Then for a laugh add in the Tenma 72_2640 (E14 2478800)
    These three span a price range from £179 to £850.
    The only place I'd want to try to get in on the market is at twice the price again (ie >£1700)   - because I'm sure that AIMTTi who've been making power supplies for years can beat me on their home ground and I know that I don't want to play at the bottom end (those Tenma things must have an ex works price of less than £100).
    Of course no one will buy a power supply from me for 2k unless it's something niche and exotic - but if you have an idea in that area it could work. (Keysight are there of course !)
    But if you want to bounce about ideas about how to be more accurate, lighter etc it'll be fun to talk about it.
    JMO - YMMV !!
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to mudz
    Mudz asked [about Switching Pwr Supplies over Linear One's]>>...
    1) less bulky/weight
    2) Compact
    3) portable
    4) Stablility with accuracy
    5) much Cheaper than market solutions
    ELY Reply>>
    1) Yes
    2) Yes
    3) Yes
    4) MK is more knowledgeable about this Point
    5) IDK (I Don't Know) actually IDT (Don't Think) so.
    I believe all those Cell/smartphone/Tablet Chargers are Switching Pwr Supplies. They are cheap b/c of your first Three points. Economies of Scale. Our
    "One(ies)-Two(ies)" Switchers will never achieve that Level. My interest in SPS (Switching Power Supplies) is more IC (intellectual Curiosity) than a "want" to build such. That is why I mentioned that I am waiting for that MOOC course at www.coursera.org to be offered again. The one about Switching Power Supplies.
    ELY aka USCDADNYC
  • COMPACT
    COMPACT over 10 years ago in reply to mudz
    As mentioned in one of my previous reply (in a joking way) - Linear Power supplies dissipate excess energy as heat and if there's a large difference between the input and output there's also lots of heat generated.
    Since DC Linear Power supplies generally work on a DC input and don't use a capacitor or inductor to store a self generated oscillating energy field thus they are much quieter than switching power supplies but usually contain huge and heavy stepping AC transformers to get the input voltages to a suitable level.
    The Apple ][ was one of the first personal computers to use a SMPS.  This was to reduce its weight by not needing a heavy step down AC transformer.
    It looked quite impressive, professional and very safe in its cadmium plated steel escutcheon.
    SMPSs are quite complex and bad things can happen when things go awry!
    That's one reason why there's such a variety of them and not just a single design to cater for all circumstances.
    One could view an SMPS as a radio transmitter that converts its outputs as a set of DC voltages. (by way of suitable filtering!)
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to COMPACT
    If we were all to use SMPS, what would we do w/ those "heavy stepping AC transformers"?
    Answer(s): Use them to Drown Minions. (only Kidding!) Use them to Drown Kittens (half-Heartedly) Kidding!BTW I still have a Transformer from an S-100 Imsai Computer (circa 1976?). It is about 3/4 the size of a (bread/bagel) Electric Toaster. Think of all the Kittens that will be in danger. Heck, forget the Kittens. The Transformer is so heavy, I am thinking Cats.
    ELY aka USCDADNYC
  • COMPACT
    COMPACT over 10 years ago in reply to uscdadnyc
    Did you build your S100 computer in the 1970's?
    And how about the really thick copper wires and giant filter capacitors that are larger than kittens for the +8V lines for the S100 bus!
    My S100 computer was internet connected, is yours?
    The eternal power supply question!
    There's so many design variants and optional functions that it's difficult to settle on a final design specification.
    Rather than a one for all solution, it could be a better choice to make several purpose specific supplies targetted towards what they are likely to be used for.
    Theres also so many cheap ready made converters available that it might be worthwhile using lots of different off the shelf components too.
    I had similar problems after I spilt a glass of wine on a homemade supply, since I already had plenty of power related solutions and I wad being lazy, I went for just buying a Digimess bench supply and making targetted solutions where needed!
    That said, I always appreciate seeing the design and solutions of home built supplies!
    ιμςιε
    The Main reason folks build there own is first and formost for the experiance  (Kinda New EE 101) , it can teach you a whole load about electronics, OpAmps, Power Transistors, Feedback, Transient Response, Voltage References, Temperature stability to name just a few and at the end of it you have something usefull
    The second reason is because you have a few of the expensive parts laying arround already and there just the ticket to build a PSU on a budget, Im talking about perhaps a transformer from an old AMP, got a box to put it in, have an LCD or LED display to show the volts and amps (Or an analogue one) etc. Then the cost is minimal for the rest and you still get the benefit of learning and something usefull
    If the reason you need one is purly professional / Must have one for the hobby but are an experianced EE then yes, often much cheaper to simply buy one, albeit low end.
    My series on building one is aimed at the folks wanting to learn and gain the experiance, and now im going to extend this to making it fully programable, even remotly so it will potentially be comparable with ones exceeding many hundreds of dollars.
    Peter
  • COMPACT
    COMPACT over 10 years ago in reply to Robert Peter Oakes
    You can't go wrong with an LM317 operating in Linear regulation mode!
    Making its voltage programmable is as simple as incorporating a I2C/SPI/Serial controlled resistor.
  • COMPACT
    COMPACT over 10 years ago in reply to COMPACT
    Voltage regulators depend on good feedback!
    Robert Peter Oakes over 10 years ago in reply to COMPACT
    Very true, and unless you have that feedback for the volts directly from the load or as close as possible (Banana Binding posts are often the nearest convienent spot), you will be prone to errors int he output, especially when drawing high currents, this is where using an LM317 and the like starts to fail from a design. There great chips, just sensing is local to the chip, not the load. For most purposes this is ok, but if you want a precision power supply, it wont work as well as could be needed
