Ask an Expert Forum Power Supply for Home lab?
  • Replies 136 replies
  • Subscribers 345 subscribers
  • Views 20671 views
  • diy_power_supply
  • function_generator
  • power_supplies
  • diy
  • voltage/current
  • power_supply
  • power_meter
  • variable_power_supply
See a helpful answer?
mudz
mudz over 10 years ago
I am starting this year with different projects. Indeed, I need a power supply which I felt for so long is the main missing component in my small home lab. Currently, I am using PC SMPS, Transformers, and different adaptors to power up different projects and kits.
Many times I felt need of a variable power source but I did that with two different power supplies, but it is time consuming. And many more things to say but its just a waste of time to write and for yourself to read...... Now Its too much and I'm going to build one good power supply. Previously I'm fulfilling my power supply needs by using a adaptor and then using a voltage regulator(7805, 7809, 7812, LM317..) afterward for my projects.
So, what do you suggest?
Also I'm going to include few more additions to it like function generator, power consumption meter.
So what do you suggest what will be the best thing to make a good power supply?
An IC?
A Microcontroller? like PIC
Just build a box consisting a transformer/adaptor with voltage regulator and few pots?
Do tell me which will be better to use? A microcontroller or IC available in market for specific task for example Function generator IC? I'm confused should I go with a microcontroller and make my own program to do these tasks or should I buy an IC for individual task and then using a controller to control all?
mudz
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago +3
    I know this is self promoting but I am in the middle of a set of tutorials on building a LAB / Bench power supply and accessories I start with the basic building blocks, explaining in practical terms what…
    michaelkellett over 10 years ago +2
    There is no best - it depends what you are doing - I have loads of different power supplies (it's my work not just a hobby so they can be paid for if needed.) My favorite general purpose supply is a rather…
    Robert Peter Oakes over 10 years ago in reply to mudz +2
    I would suggest starting with a basic naalog design (As I have shown in my series), understand its operation, then it should be a simple extension to add DAC and ADC monitoring this way it seperates the…
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to COMPACT
    Sort of Good News. www.coursera.org is running the Univ Of Colorado's Power Electronics Series again(?) staring 25JAN16. I think it starts w/ the first of six courses which can lead to a Specialization Certificate. There is Tuition for the Certificate. But if you forgo such accolades, it is FREE. I think just "auditing" the first Course will be sufficient to satisfy my Curiosity. I have two higher-ed Degrees already. One person said to me: "If you get any more Degrees. You will become a Thermometer." As a Patent Atty, I rather give a witness the 3rd Degree, than receive anymore Degrees myself. So Check It Out. At the site Key-on: "power electronics"
    USCDADNYC
  • COMPACT
    COMPACT over 10 years ago in reply to uscdadnyc
    Being an Autodidact I have at least 3 degrees of freedom! - XY and Z (Cartesian) or  theta, rho and phi (Spherical)
  • uscdadnyc
    Being an Autodidatic, you should love the Movie "Good Will Hunting." I can go only so-far w/ complete (un-directed) Self-Study, I hit a road-block and I can be stuck for Days (even) Years. MOOCs are a little better, at least you can ask Q's of the Instructors. For me, I am playing in the "sand-box", WRT MOOC's, more for Intellectual Curiosity than attaining a Academic Goal. Of course some of my Interest wanes when it Math gets difficult. I watched a Quantum Mechanics MOOC even though I had Atomic Physics over 40 years ago. I wanted to know what the Buzz, QM was about in today's world. (small semiconductor geometries are subject to QM effects). I took a Thermodynamics MOOC, although I had Physical Chemistry "101", etc
    For those NOT in the "Sand Box", but are studying  (for Real) or Have Kids that are actual Students, I have some Tips:
    1. Make your own Study Notes. Don't rely on somebody else's Note. If you create the Notes, you remembers the Notes
    2. Try to have a Study Partner who is your equal. People of Disparaging academic talents can bring you down. But if your Study Partner is Good-Looking, it is OK.
    3. [I am Not a Shill for the House] but WRT #1, BUY a hand-held OCR Scanner (like Ectaco C-Pen, OR Iris(pen), etc.). you can copy directly from your Printed Textbook into your Office-like Applications. But although these devices make it real Easy to incorporate Book-matter to your Notes, you still have to be Judicious in what you Scan (copy).If you Yellow "HighLight" everything. You are HighLighting Nothing.
    4. Keep in mind the Saying "Do not Schooling interfere with your Education"
    -USCDADNYC
  • COMPACT
    Thanks for the great post!
    As a Autodidact I found that it was important to understand differential calculus in multiple dimensions.
    Faraday couldn't express his findings empirically and got stuck.  James Clerk Maxwell was able to express Faraday's findings as simplistic complex equations (It sounds like an oxymoron but it's not) to make it easy for the rest of us to understand it.
    @DAB is working on his own theories of everything. Its very interesting stuff.
    I wouldn't be surprised if in the future we find that the cosmic background radiation is caused by all of our wifi transmissions that won't fade over time.
    As for computer design, Tommy Flowers doesn't receive enough credit.
  • uscdadnyc
    To Compact:
    I hope your are feeling Better today.
    WRT Faraday & Maxwell, I heard about that, on how Maxwell (as in Maxwell's E-M Equations) expressed Faraday's Theories/Ideas.
    WRT2 F&M. Being able to bridge STEM (Science Technology Engineering Math) Subjects to the Public, is difficult. Try to get to
    www.wnyc.org -Shows -Leonard Lopate Show -Search "Neil deGrasse Tyson" There was a short segment about the intersection of Science (STEM) and Public Policy. I wish NdeGT would run for POTUS (President Of The US) , he is "Light Years ahead of any of Fools currently running" [Pun Intended]
    What is @DAB?
    IDK (I Don't Know) about WiFi possibly contributing to Cosmic Background Noise. It (WiFi) is a pretty weak signal compared to TV/Radio, as was the basis for the Movie "Contact". Planck's Equation E=hc/(lambda: wavelength) Sorry, I could not find a (lambda) in the Equations Editor. Lambda for WiFi May Not be small enough to
    make (E) Large, b/c Lambda is in the Denominator. This is a First Impression, so I may be Wrong.
    I treasure these discussions w/ you. Thx. I hope we are not straying too far off-Topic, causing other contributors to be Bored. My Apologies in Advance.
    -USCDADNYC
  • COMPACT
    This is DAB! http://www.element14.com/community/people/DAB
    Accumulate all the WiFi transmissions along with Microwave Oven cooking and you get a hell of a lot of power!
    We advertise Lamb(da) for Australia Day!
    DAB over 10 years ago in reply to COMPACT
    Actually, the CBR is caused by stars.
    When a star begins to fuse material, it creates high frequency photons.
    As time passes, the photons become lower frequency as they have more mass.
    Contrary to popularly stated theory, a star is very old by the time it produces visible and IR photons.
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to DAB
    To the all the bloggers on this Thread, I implore you all again to provide a little info about yourself. Maybe just Town, Country, Approx. age (ex: Baby-boomer, millenials, etc). This in order for ALL of us to tailor our comments to the Target Audience.
    Case in Point is my Reply to DAB, about CBR.
    To DAB: I spent some time at AT&T Bell Labs in the early 1980's, this maybe 3 years after Scientists Penzias/Wilson won the Nobel Prize in Physics in 1978 for work on CBR. I was more on the implementation/field-testing than Pure Research of P&W. Smart People but suffered from NIH syndrome (Not Invented Here). If it was not done at Bell Labs it was No Good. Talk about Hubris. Where is AT&T Bell Labs today?
    DAB wrote>>...As time passes, the photons become lower frequency as they have more mass.
    ELY reply>> Does this gaining Mass have anything to do w/ the Higgs Boson?
    AAR this was also to demonstrate how I could have abbreviated/expanded on my reply based on more info about my Target Audience. Anybody outside the USA, even know what AT&T stands for? Or do they know Bell Labs?. Context is everything, please provide me w/ context. If you are in a country using the Metric System, I will use Metric Units and the Centigrade Scale. Please help me to provide better tailored info.
    Full Disclosure: Edward Yee is my real name, aka USCDADNYC, aka ELY. Lives in NY NY  USA, Baby-Boomer. You can even find my phone/physical-addr by vetting thru the Website: www.uspto.gov
  • COMPACT
    AT&T = Yankee Phone and Morse!
    As for me I'm fair'n'height! and I'm no criminal so I don't use Con Text either.
    Centipedes use Centigrades and Centimetres!
    DAB over 10 years ago in reply to uscdadnyc
    Hi Edward,
    It sounds like you had access to some really neat projects.
    I am a disabled/retired systems engineer with an extensive physics background.
    Over the last four years or so, I used complex problems as a way to distract my brain from the pain caused by my injury.
    During that exercise, I found a very simple way for the universe to work, which I documented in my book "I Killed Schrodinger's Cat!"
    I have not found any need for the Higgs or any other Boson to make the universe work.
    I have documented a stellar fusion process that creates photons as part of the sequence at each level of fusion.
    As the star makes more massive objects, these are entangled to produce photons, so the more massive/lower frequency photons are created as the fusion process progresses.
    If you are interested, I love to talk about the processes I have defined.  My coauthor and I are still working on the theory and we are currently redefining the Periodic Table as we have found a better way to account for what is inside of atoms.
    So far we have identified photon exchange as the main way for atoms to exchange mass and energy, which confirms thermodynamics measurements, but eliminates the need for entropy.
