Ask an Expert Forum Power Supply for Home lab?
  • Replies 136 replies
  • Subscribers 345 subscribers
  • Views 20704 views
  • diy_power_supply
  • function_generator
  • power_supplies
  • diy
  • voltage/current
  • power_supply
  • power_meter
  • variable_power_supply
See a helpful answer?
mudz
mudz over 10 years ago
I am starting this year with different projects. Indeed, I need a power supply which I felt for so long is the main missing component in my small home lab. Currently, I am using PC SMPS, Transformers, and different adaptors to power up different projects and kits.
Many times I felt need of a variable power source but I did that with two different power supplies, but it is time consuming. And many more things to say but its just a waste of time to write and for yourself to read...... Now Its too much and I'm going to build one good power supply. Previously I'm fulfilling my power supply needs by using a adaptor and then using a voltage regulator(7805, 7809, 7812, LM317..) afterward for my projects.
So, what do you suggest?
Also I'm going to include few more additions to it like function generator, power consumption meter.
So what do you suggest what will be the best thing to make a good power supply?
An IC?
A Microcontroller? like PIC
Just build a box consisting a transformer/adaptor with voltage regulator and few pots?
Do tell me which will be better to use? A microcontroller or IC available in market for specific task for example Function generator IC? I'm confused should I go with a microcontroller and make my own program to do these tasks or should I buy an IC for individual task and then using a controller to control all?
mudz
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago +3
    I know this is self promoting but I am in the middle of a set of tutorials on building a LAB / Bench power supply and accessories I start with the basic building blocks, explaining in practical terms what…
    michaelkellett over 10 years ago +2
    There is no best - it depends what you are doing - I have loads of different power supplies (it's my work not just a hobby so they can be paid for if needed.) My favorite general purpose supply is a rather…
    Robert Peter Oakes over 10 years ago in reply to mudz +2
    I would suggest starting with a basic naalog design (As I have shown in my series), understand its operation, then it should be a simple extension to add DAC and ADC monitoring this way it seperates the…
  • COMPACT
    COMPACT over 10 years ago in reply to DAB
    Hi Edward,
    I too am a retired due to illness.
    Unlike DAB who is very clever I just make pot luck guesses and also try to add a bit of levity to get through my days.
    I'll make pot luck remarks such as;
      "DC is just AC with a very low frequency!"
    But unlike Tesla I won't make statements like;
      "c = infinity" (until it is proven or disproven.)
    Very Compact (or Very Expanded) depending upon which part of the Universe we're in.
    (By my definition - Multiverses are encompassed in a single Universe!)
    A bit like a Venn Diagram!
  • COMPACT
    COMPACT over 10 years ago in reply to COMPACT
    The net effect would be "Quantum Physics without dice" but without everything being deterministic!
    A photon is a dumpling served in a Vietnamese soup.
  • COMPACT
    A dumb cow is an oxymoron
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to COMPACT
    IDK (I Don't Know) about Photons possibly having Mass? At certain Levels/Situations Matter/Energy are interchangeable (E=MC2 ). I guess I should continue that MOOC QM course I started  at www.coursera.edu. the QM course offered by the USA university of Maryland. I got as far as the Time-dependent Schrodinger Equation. But stopped b/c #1) I had got my Answer to the Q: Why QM? A (being): small semiconductor geometries are subject to QM Effects. #2) The math was getting Hairy and I suddenly remembered that I had given away my Math Bible, Krezszig "Advanced Engineering Mathematics" C2 . {sorry about the artifact, I am slowly starting to use the Equations Editor). W/O much success as evident by my mistakes here.
    AAR Thx for posting the Ponder(ables)/In-Ponder(ables) to which I may/may-not be able to add to the discussion.
    USCDADNYC, , NY NY USA
    michaelkellett over 10 years ago in reply to uscdadnyc
    Kreyszig  - I'm keeping mine just in case - which shows what a hoarder I am since I have opened it exactly once with the intention of looking something up in the last 42 years !
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to michaelkellett
    To MK:Was your edition of AEM "red" in color and about 6.5"x9.5"x2.5" (17x24x6cm). How I miss that book, I guess I can get a copy over the Internet.What book did you have for Fresh/Soph General Physics? What Calculus Text? US or outta country Higher Ed institution? I was BSEE 73' Syracuse University, JD 1990 NYLS.
    You might saw I went from a 2nd Rate Engr School to a 3rd Rate Law School. My trajectory is definitely downward.
    WRT "Hoarding", I take an approach similar to the NYS EPTL (Estates Powers, Trust Law) by analogy. You cannot execute a "Will" w/o knowing the metes & bounds of your Personal/Real (land) Property. Similarly, if you know what you have and can show a compelling reason to "keep" such, in my eyes, it is Not Hoarding. IDK about in other jurisdictions outside of NYS (USA), but this is pretty much English Common Law based. So you guys/gals in NZ and/or Aussie Land are covered
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to uscdadnyc
    BTW anybody else going to participate in that "power electronics" MOOC at www.coursera.edu? We can use this forum to exchange Q's/comments. And maybe
    exchange "GOOD" (if at all possible) Puns/Jokes. LOL
    DAB over 10 years ago in reply to uscdadnyc
    Hi Edward,
    Unfortunately, E = mc^2 does not mean matter and energy are interchangeable.
    This is a often repeated but wrong interpretation of what Einstein really said.
    The full context of his equation says that the maximum kinetic energy E of a mass object m occurs when it is travelling at the speed of light c.
    Mass and energy are separate items and both are 100% conserved in all reactions.
    The equation also indicates that there can be NO massless sources of energy.
    So the faster a photon vibrates, then the less mass it has.  This fact means that Planck's radiation law is wrong as he has higher frequency photons with more energy, which is not confirmed when you include the mass.
    So if you are going to use Quantum Mechanics, you first need to throw away all of your massless objects and replace your discrete quanta as individual photons.
    Oh and by the way, the standard atomic model is also wrong.
  • COMPACT
    Seven!
    It's my cat playing dice again!
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to DAB
    DAB wrote>>...
    ELY reply>> Forgive my stating the special case of Einstein's Famous Equation. Where v is negligible when compare to c. My bad.I guess I should stated the formula as: [having tbl w/ the equation editor, so this longhand] E = (M x c(sqrted)/ Sqroot (1- ( v(sqrted)/c(sqrted)). Is this what you are alluding to?
    AAR I had to open up my Atomic Physics Text from Fall 71 or Spring 72 for this one
    AAR2 I have just about exhausted my knowledge of (atomic/relativistic) Physics. Maybe I should proceed ahead (from where I stopped) WRT that QM MOOC. Could you (DAB) look at the curriculum to see if any of the concepts are worthwhile. Link is: https://www.coursera.org/course/eqp
    Will any of this gobbly-gok help me understand what is behind the science/math of your Premise(s)/Theories ? Not to slight you, but I would prefer a Third Party Source for the Basic Science involved. Can you refer me to a "Mainstream" Source? I don't want this to become  a  PHD level learning experience. Just the Basics, if at all possible.
