Ask an Expert Forum Power Supply for Home lab?
  • Replies 136 replies
  • Subscribers 345 subscribers
  • Views 20711 views
  • diy_power_supply
  • function_generator
  • power_supplies
  • diy
  • voltage/current
  • power_supply
  • power_meter
  • variable_power_supply
See a helpful answer?
mudz
mudz over 10 years ago
I am starting this year with different projects. Indeed, I need a power supply which I felt for so long is the main missing component in my small home lab. Currently, I am using PC SMPS, Transformers, and different adaptors to power up different projects and kits.
Many times I felt need of a variable power source but I did that with two different power supplies, but it is time consuming. And many more things to say but its just a waste of time to write and for yourself to read...... Now Its too much and I'm going to build one good power supply. Previously I'm fulfilling my power supply needs by using a adaptor and then using a voltage regulator(7805, 7809, 7812, LM317..) afterward for my projects.
So, what do you suggest?
Also I'm going to include few more additions to it like function generator, power consumption meter.
So what do you suggest what will be the best thing to make a good power supply?
An IC?
A Microcontroller? like PIC
Just build a box consisting a transformer/adaptor with voltage regulator and few pots?
Do tell me which will be better to use? A microcontroller or IC available in market for specific task for example Function generator IC? I'm confused should I go with a microcontroller and make my own program to do these tasks or should I buy an IC for individual task and then using a controller to control all?
mudz
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago +3
    I know this is self promoting but I am in the middle of a set of tutorials on building a LAB / Bench power supply and accessories I start with the basic building blocks, explaining in practical terms what…
    michaelkellett over 10 years ago +2
    There is no best - it depends what you are doing - I have loads of different power supplies (it's my work not just a hobby so they can be paid for if needed.) My favorite general purpose supply is a rather…
    Robert Peter Oakes over 10 years ago in reply to mudz +2
    I would suggest starting with a basic naalog design (As I have shown in my series), understand its operation, then it should be a simple extension to add DAC and ADC monitoring this way it seperates the…
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to uscdadnyc
    To Compact:
    You were able to get registered at coursera.edu for the "Intro to Power Electronics" course, Correct? B/C Peter Oakes is/had problems w/ registration. He is I believe is in Canada, while you are in  NZ, correct? AAR in that screen Shot, he posted [17JAN16 923PM] on the Left side of the Photograph are two Receptacles (1-Red, 1-Blk) They are Female receptacles that can accommodate "Banana Plugs". Remember our discussion about Bananas?
    Robert Peter Oakes over 10 years ago in reply to uscdadnyc
    I looked at other courses and there ok, shows a registration and everything
    Maybe a couple of years ago (Sept 2014) I register with intention to do it and never did ??, and it wont let me do it a second time
    DAB over 10 years ago in reply to uscdadnyc
    Hi Edward,
    Have no fear, some of the University crowd have called me a fool and even a fraud.  Unfortunately non read my book, so they really had no basis for their assessment.
    My theory only uses algebra, trigonometry and two basic forces.
    I doubt that any course on Quantum Mechanics will provide you with an understanding of the science involved.
    Your basic 1972 physics book will provide you will the fundamental issues.  QM arose from some scientist attempt to fit their ideas into a model.  Unfortunately, their math does not work.
    My approach describes almost all of the effects observed in the universe at the macro and micro scale.  Plus the math works to support the theory.
    I am still evolving parts of the theory.  Along the way I have found that many assumptions behind QM are not correct or even feasible.
    So I would recommend that you hit your local library, you can find lots of books and articles on QM and the many interpretations of both the theory and its correctness.
    I would also be wary about relativistic physics.  I am seeing evidence that Einstein was wrong, but I do not have the time to explore that particular issue.
    DAB over 10 years ago in reply to COMPACT
    Does that mean that she does not precipitate?
  • COMPACT
    COMPACT over 10 years ago in reply to uscdadnyc
    Hi USCDADNYC!
    I haven't registered for the Power Electronics course.
    However I use to design and build various types switch mode and linear power supplies and seen the vast improvements to them over the years.
    A popular modern style of SMPS is the flyback converter. I've seen it used for many wall warts.
    I'm not from NZ but have spent time there many decades ago. I am transient. One moment it is here and the next elsewhere!
    Dark Matter is for Macho Wimps who want to verify the existence of Axions, Super Symmetry and other cockamamie ideas!
    I wonder how close they are? Cold, Warm or Very Hot (or have not temperature at all!).
    I'll see what I can kludge up for a Dark Energy converter.
    It would not surprise me that the universal background microwave radiation is related.
    Q: What do you call a power supply that can provide an unlimited range of voltages?
    A: Omnipotent!
    Positive feedback gives you great rhythm!
    Very Compact
    NOTE: SAFETY FIRST - MAKE SURE YOU USE THE PROPER PRECAUTIONS WHEN DEALING WITH POWER.
    Safety equipment such as Isolation transformers should be used where necessary.
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to COMPACT
    Peter Oakes wrote>>.. it wont let me do it a second time..
    ELY Reply>>B/C of a earlier attempt at this particular course (a few years ago)? That Would Be a coincidence! USCDADNYC is the Poster Child for NOT completing Courses (albeit NOT for Certification), and USCDADNYC does not remember being hindered by coursera?
    AAR if you forego the certificate and ability to pose direct Q's to the Instructors, there is a way for you to view the Course Videos.
    Again refer to my 18JAN26 3:14PM Post and send me the info I requested. To this end, I have other two Q's 1) are you familiar/use w/ Google Drive? 2) Are you familiar/use w/ DropBox?
    -USCDADNYC
  • uscdadnyc
    To DAB:
    DAB wrote>>...
    ELY reply>>Those are BOLD Words my friend, "...their math does not work..." Like in the Movie "Pulp Fiction" where the Travolta character said the same words to a Drug Dealer who boasted about his Product (certain type of Cannabis). AAR as I understand it, Classical (Mechanics) Physics fails at the small scales involved. Instead of defining a particle as being in Places, QM describes the Particle in Time. Fourier Series, Fourier Transforms leading to the Schrodinger Equation. As an undergrad EE, I used Fourier Analysis, so for ME, application of it to QM is NOT far a Stretch. Perhaps, I will continue w/ that QM course at coursera.org. They (the professors) promised in their Intro Lecture that they will show that QM "works" as predicted in Observed Phenomenon. If this bears out (by the Professors in the QM Course), you will have a Question(s), Postulated Theory (of the workings), Observable Results. That works for me, I do not know about you.
  • COMPACT
    Astrologers work from observations too.
    Are they accurate?
    My power supply is accurate when I watch it but if I don't will it suddenly apparate to two different locations.
    It begs the question - "Does QM rely upon Harry Potter magic?"
    Does JK Rowling know something we don't?
  • COMPACT
    COMPACT over 10 years ago in reply to COMPACT
    I like Linear Technology and Wurth Elektronik magic.
    A Linear Tech IC with a Wurth Inductor plus a few bits equals a great power supply!
    Wurth's Trilogy of Magnetics Design Guide is a fantastic textbook.
    I highly recommend it!
    Banana!
    Robert Peter Oakes over 10 years ago in reply to COMPACT
    Well I spent many years as a calibration engineer in a standards lab and the only thing we absolutly guaranteed was the accuracy at the time of test, after that we can only hope based on previous experiance
    And we all know the old fact that making an observation changes the thing we are observing and this is very true of electronics
    Even a good DMM will affect the real voltage in a circuit, and the higher the impedence of that circuit the more it will be affected (10Mohm in parallel with whatever and a few pf in parallel with whatever) as the ratio of current drawn to make the measurement is more relative to the measured circuit...
