Ask an Expert Forum Resistor
  • Subscribers 328 subscribers
  • Views 1022 views
See a helpful answer?
Resistor
Hi, i have just pulled a blown resistor from my TV's power board, on the schematic it is shown as 3.3kj 1W(s) and i am finding it hard to find a replacement, any idea's
  • peterjcs23
    peterjcs23 over 10 years ago
    how about this:
    MFP1-3K3 JI - WELWYN - Through Hole Resistor, MFP Series, 3.3 kohm, 1 W, ± 5%, 350 V, Axial Leaded | Farnell element14
    or, if the resistor is blown it may be under rated so use a 2W part such as:
    MCF 2W 3K3 - MULTICOMP - Through Hole Resistor, MCF Series, 3.3 kohm, 2 W, ± 5%, 500 V, Axial Leaded | Farnell element14
  • peterjcs23
    peterjcs23 over 10 years ago in reply to peterjcs23
    also you need to watch out for the voltage rating of the resistors, look at the datasheet before you buy or install. Do you have any idea of the voltage on the original resistor, it could be high in an old TV...Peter
    Former Member over 10 years ago in reply to peterjcs23
    Thx Peter, i am struggling to find data sheet, is kj the same as kohm, the tv is Samsung LE23R86WD power board BN44-00158A
  • peterjcs23
    peterjcs23 over 10 years ago in reply to Former Member
    http://www.farnell.com/datasheets/1716725.pdf
    is the link to the 2W part data sheet.
    http://www.farnell.com/datasheets/1851677.pdf
    is the 1W part data sheet.
    I think kj is kohms does the part have any markings?
