Ask an Expert Forum Automobile engine oil curing
  • Subscribers 303 subscribers
  • Views 759 views
See a helpful answer?
Auto maintenance the most crucial one annulus is certainly engine nursing, and maintenance, engine is the most important means of course is to let it get the most effective lubrication, correctly use oil undeserved can make the engine life extension, still can save fuel, otherwise it will backfire. Owner'd better develop weekly check the oil of habit, will replace the oil remaining oil with maintenance in the car, just sitting pretty.
Oil as auto engine lubricant, not only lubricate, abrasion resistance, but also can cooling, clean, rust, anticorrosion, anti-oxidation functions. The good quality of the lubricating oil in the engine normal operation has a very important impact. Good oil, especially the total synthesis of oil in addition to engine protection, reduce the number of oil outside, also can save petrol overhead. Although than common oil your two times, is the best choice for many owners. If choose inappropriate or pursues only temporarily cheap buy inferior quality of product, can cause engine early wear, reduce engine life, serious when still can cause "pull cylinder, hold tile" malignant accident.
  • wendypreston
    wendypreston over 14 years ago
    Hi Linkin,
    Do you have a question in there for the experts?  Thanks!
    Wendy image
