Ask an Expert Forum RF TUNING VARACTOR DIODE
  • Subscribers 336 subscribers
  • Views 594 views
See a helpful answer?
Hi  All,
What do they mean by
  • Capacitance Cd Max @ Vr F:2.86pF
Can you guys recommend me a  VARACTOR ranging from 0.7pF to 10pF?
  • Andy_Brook
    Andy_Brook over 15 years ago
    Hello
    Farnell stock a range of Variable Capacitor products, nothing covering the C band you have specified, but the two stock codes below cover 0.8-10pF.
    1692432
    1692433
    http://uk.farnell.com/jsp/search/browse.jsp?N=1000237+5602234+5602235+5602245+5602246+401&No=0&getResults=true&appliedparametrics=true&locale=en_UK&catalogId=&prevNValues=1000237&filtersHidden=false&appliedHidden=false&originalQueryURL=/jsp/search/browse.jsp%3FN%3D1000237%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_UK%26catalogId%3D%26prevNValues%3D1000237
    Hope this helps.
    Andy
  • lpetacchi
    lpetacchi over 15 years ago
    capacitance ratio over 10 is uncommon and limited to VHF devices (Si hyperabrupt diodes with Ctmax >20pF). If you are working in this range of frequency, one solution is to series connect a number of suitable varactors to scale down the capacitance. BB153 or BB639C/BB659C are a good starting point. 30V (per diode) are usually needed to Cdmin, so bias circuitry is not trivial.
