Ask an Expert Forum LM627N
  • Replies 8 replies
  • Subscribers 338 subscribers
  • Views 1553 views
See a helpful answer?
LM627N
A project I am building requires an LM627N Op Amp. I can't find this device in the Element 14 catalog. Is there an equivalent type that I can look for?
Thank you.
Norman
    I can't seem to find anything on this chip.  Do you have a data sheet you could post for it? Or could you possibly post a schematic or something for the project?
    Andrew
    I have a datasheet but it is in Chinese. You may be able to make sense of it by looking at the block diagram. If noy I can send you data on the project.
    Regards
    Norman
    imageLM627 datasheet.pdf
    Ok, well ive found a couple things.  First off while just going through google searches it seemed that it came up alot that an OP27GPZOP27GPZ could replace it...??? Im not 100% sure of this, as the ones i have looked up are not exactly the same as in your data sheet.  From looking at the datasheet I can tell you a few things (It being in chinese I cannot guarentee all of these, but im pretty sure);
    1. It is an 8 pin DIP Op Amp (Im sure you already knew this)
    2. It has a single comparator
    3. The supply voltage is 15V (optimal) (3.5V to 18V operating range (not sure???))
    4. The slew rate is 4.5V/us
    If you go on whatever website you use to get parts and put in these parameters you may be able to find something similar.
    Andrew
    Thanks for that info. Now I have a clue as to what characteristics to look for.
    Regards
    Norman
    No problem. Tell me if you need any more help with your project image
  • kemmi
    kemmi over 15 years ago in reply to e14 Contributor
    refer LM627N datasheet,I suggest OPA227  or OP228 replace it.
    Andrew
    Thanks for your offer.  Will let you know if I am stuck!
    Regards
    Norman
    e14 Contributor over 15 years ago in reply to kemmi
    Kemmi
    Thanks very much for your help. Greatly appreciated!
    Regards
    Norman
