Ask an Expert Forum best wireless platform to transmit hd video?
  • Subscribers 340 subscribers
  • Views 572 views
  • video
  • 60 ghz
  • 2.4 ghz
  • 5_ghz)
  • wireless transmitter
See a helpful answer?
hello everyone,
i am trying to decide what is the best way for me to transmit an hv video using wireless communication.
the need is to transmit around 100m/330ft and keep the latency as minimal as possible.
i read that transmission using wifi on 5GHZ should be the right solution but i am worry about the effective range.
as it seems for the future technology, 60GHZ will be optimal once it will be stable enough to handle such range and obstacles on the way.
thanks and best regards,
ron weiner
  • clem57
    clem57 over 10 years ago
    If latency may be a problem, you need multiple channels to cut down the latency issues.
    Clem
    e14 Contributor over 10 years ago in reply to clem57
    can you give me an example for multiple channels solution?
    do you think working on wifi on 5GHZ would work and would do the job?
  • clem57
    clem57 over 10 years ago in reply to e14 Contributor
    What Is Multiple-In Multiple-Out (MIMO)?
  • mudz
    mudz over 10 years ago
    You can try Wireless P2P modules we use in telecom sector to provide P2P connectivity with very low latency even for long distances.
    I've also mentioned of of those P2P devices in a blog post here :Testing Home Automation with ARM mbed IoT Starter Kit.
    These are basically used to provide Internet over air and have good bandwidth so you can easily transfer multiple HD videos. Those AirGrid M5-HP modules are able to provide long range distance connectivity ~ upto 5KM - 7KM. So you can use this module for other applications also.
    mudz
