Ask an Expert Forum cadsoft eagle which connector for a 100mil center 1x4 connector
  • Subscribers 338 subscribers
  • Views 383 views
See a helpful answer?
This is a fairly easy question to answer.  I need to add a number of 1x4 100mill center drill through holes in a very simple design.
The spacing should be the same as the standard debug board, so I can put in 1x4 solder through hole connectors.
Which connector from the cadsoft eagle connector library should I use?
Thanks in advance.
  • clem57
    clem57 over 10 years ago
    https://learn.sparkfun.com/tutorials/using-eagle-board-layout
