Ask an Expert Forum Have a question about Sensors? Ask our expert Jane Awittor
  • Replies 27 replies
  • Subscribers 342 subscribers
  • Views 3779 views
  • power_integrity
  • solid_state_relays
  • experts
  • ask_an_expert
  • power
  • ask_the_expert
  • power_electronics
See a helpful answer?
patkelly
patkelly over 14 years ago
Jane's Expertise:image Sensors.
About Jane:
Jane is a technical specialist for Panasonic, supporting a broad line of sensors such as pressure, passive infrared, active and infrared array sensors.  Whether it’s a new design or an upgrade to existing design, Jane has the technical expertise to support customers with their various sensor requests.
She is an electrical engineer with 5 years of experience specializing in Passive Infrared (PIR), Infrared Array and Pressure Sensors. Focused on technical sales support and interface to research and development teams in Japan. Developed proposals for new product enhancements, competitive product studies and SWOT analysis.
Read more about Jane
If you need help on anything about Electromechanical Signal, Power, and Solid State Relays, please post your question here!
If your not already, you'll need to login or register to ask your question - just click reply
    michaelkellett over 13 years ago in reply to e14 Contributor
    I was hanging fire to see if any one else would help you - apparently not.
    Can you post the ciruit you are using and it should be possible to help.
    e14 Contributor over 13 years ago in reply to michaelkellett
    Thanks for the reply mike!
    here is the circuit i am using right now: https://09fa4394-a-62cb3a1a-s-sites.googlegroups.com/site/osamaslab/Home/projects-list/pir-sensor-based-alarm/PIR.pdf?attachauth=ANoY7cqVwgjo8GD24M7gtClV6sAl2cPgP0NfLvO1AP0Zi4yFmPhbgJvvoTZO7mJf2pBeTekgYgfKvWU7dQ50jj9HmgmhRzINktReAirBsOeuw3dek-nmx_7uyC0xq4jD7MgWPKofB7F5bQbAv3jTRHDopDBoekpy7n4TIKufaa2DDlMjf980tJfJ9y-3xlP0L4xCvDoImHdpV_F6z3ieGcQLSILAwMJc36UNXmNgnCLqRQ1JVwEbqH-Xn_nzKE9hW58u7zxRVUX6&attredirects=1
    i think i really should use a fresnel lens or any substitue for that.. and that's my problem.. i think.. :/
    Robert, from your first post there is more wrong than just a lens - you should be able to detect hand waving easily.
    If you can make some DC measurements we can tell if your ciruit is working OK.
    Can you measure (with respect to earth), no handwaving but sensor must be connected.
    DC volts on
    ZD1 cathode (junction with R10)
    U1, pin 1
    U1, pin 7
    U1, pin 14
    U1, pin 8
    here's my measurement:
    ZD1 cathode (junction with R10)     4.4V
    U1, pin 1     355mV
    U1, pin 7     1.728V
    U1, pin 14     285mV
    U1, pin 8     358mV
    handwaving or not, the voltage doesn't change.. do i have a defective PIR semsor? :/
    Well let's work it out,
    What happens if you briefly connect the sensor S to ground with a 47k resistor.
    (It should make  a big signal and activate the relay).
    I expect the DC voltage on S is  about 335mV - could you please check.
         I'm very sorry for the late reply. I think my first sensor was defective. I am now using a new sensor i bought with a fresnel lens using the same circuit. But the problem is, it's still not that sensitive for hand waving or any movement surrounding it. Well, atleast the distance improved when i am using the soldering iron tip for about 4inches. When i probe the voltage reading between the sensor's S while i am waving my hand, 2-5 millivolts of changes occur. But when a soldering tip is near, a significant change occurs in the voltage reading. How can i adjust the sensitivity so that it can react to a simple hand waving etc.?
    thanks image
    Hello Robert,
    You would only expect quite  a small signal - tha amplifiers in your ciruit have  a gain of 9000 and the detection threshold is about 1V so you need a signal of about 0.1 mV to set off the alarm. A DMM is not the best tool to look at the signal with because it is in a difficult frequency range - too slow for AC settings on a DMM and changing too rapidly for DC settings. Use a scope if you have access to one and look on the output of the first or second amplifiers.
    Hello Sir Mike,
    Yes, i think so too. And that is my problem, i have no oscilloscope. But, my problem is already solve! I used another circuit image. Here it is: http://320volt.com/wp-content/uploads/2012/10/pir-kontrol-devresi-hareket-sensoru.png.Since, i don't have the cd4538 IC, i just put a LED to determine if i have an output from diodes D3 and D4 and yes, success!! The voltage reading ranges from a hundred millivolts to 3.+ volts when i wave my hand, make any sudden movement from a meter distance. I think that's enough for me, i can incorporate that output with an ic or a transistor to activate a relay. Thanks by the way sir for assisting me with my problem. You're very helpful image.
    but i will still look into that, i also want to learn on how to determine the gain of the amplifier in a circuit etc. so i can better understand it not just following the schematic. Maybe i'll ask you again about that if you're still willing to educate me. Again, many thanks to you sir! image
    Hi Jane,
    I am hoping you can help me with a problem.  I am using an AMN31111 PIR sensor from Panasonic.  I have it connect to a 5V source, with the output connected to an LED (via a resistor) to light when the sensor detects movement.
    When I wire it up this way, the LED flashes in a repeating pattern over and over.  If I stand in front of the sensor, the LED does stay on (mostly), but still flickers a little.
    I am wondering whether I have misunderstood the design of the sensor.  I was planning to wire it into a GPIO port of a raspberry pi (via a resistor to bring the voltage down to around 3V when high).  However, this repeating pattern of high/low has me stumped.  According to the data sheet, the sensor should only make the output go high on movement and should be open line when there is no detection of movement.
    I have tried repositioning the sensor pointing across the room, and even outdoors at night time with nothing in front of it of course.  It doesn't change the repeating pattern.
    Could you possibly advise of what I might have done incorrect?  I purchased two of these sensors and they both behave the same way.
    Thanks.
    Damien.
