Ask an Expert Forum Have a question about Sensors? Ask our expert Jane Awittor
  • Replies 27 replies
  • Subscribers 342 subscribers
  • Views 3779 views
  • power_integrity
  • solid_state_relays
  • experts
  • ask_an_expert
  • power
  • ask_the_expert
  • power_electronics
See a helpful answer?
patkelly
patkelly over 14 years ago
Jane's Expertise:image Sensors.
About Jane:
Jane is a technical specialist for Panasonic, supporting a broad line of sensors such as pressure, passive infrared, active and infrared array sensors.  Whether it’s a new design or an upgrade to existing design, Jane has the technical expertise to support customers with their various sensor requests.
She is an electrical engineer with 5 years of experience specializing in Passive Infrared (PIR), Infrared Array and Pressure Sensors. Focused on technical sales support and interface to research and development teams in Japan. Developed proposals for new product enhancements, competitive product studies and SWOT analysis.
Read more about Jane
If you need help on anything about Electromechanical Signal, Power, and Solid State Relays, please post your question here!
If your not already, you'll need to login or register to ask your question - just click reply
    Where is Ms Awittor located?  We do a "Lunch w/an Engineer" series at Chicago State University hosted by the Office of Engineering Studies.  It's hard to find female professionals.
    Marjorie Anderson
    Program Coordinator
    Engineering Studies HWH-129
    9501 South King Drive
    Chicago, Illinois  60628 USA
    Phone:  773-995-2357
    mander31@csu.edu
    Hello Ms. Anderson,
    I'm located in New Providence, NJ but we do have sales engineers in the Chicago Area who will do a lunch and learn if needed.
    Let me know what products you're interested in.
    Jane,
    I am designing street lights. What is the best sensor and method for detecting
    ambient light?
    Allen Rees
    Jane
    I work at a childrens museum and we would like to place several sensors in the ceiling (8 feet) so that when a child crosses under a sensor a musical note will be played.  Can you suggest a sensor that will work for this kind of application?
    Thanks, Gary
    Hi Gary,
    I recommend using the PaPIRS which has 5m and 12m distances.
    More information can be obtained on our website via the link below
    www.pewa.panasonic.com/components/built-in-sensors/passive-infrared-sensors/
    Hi Allen,
    For street lighting do you need the lights to come on and off when it senses someone approaching?
    We have the Napica light sensor which is used for lighting design however we have the PaPIRS which is a passive infrared sensor.
    More information can be obtained via the link below
    Thanks and let me know if you have any questions.
    Thanks for the reply.
    I am looking at "Dusk to Dawn light control".
    Allen
    Allen,
    The Napica (Light sensor) will be the best choice. Where is the location for this project so I can put you in touch with our sales team.
    Jane,
    Again thanks for the reply.
    I am located most of the time in Phoenix Arizona. We are
    designing street lights for use in Caribbean area and Africa.
    Please send me the name and number of one of your support
    people.
    Have a nice day,
    Allen
    Good day Ma'am,
    I need your expert advice. I am having a problem right now about my PIR sensor lhi 968. You see, i only have the sensor itself that's why i am creating circuits from scratch with reference from circuits i search at the internet. I am currently using a LM324 with the PIR sensor. Well, the circuit works... as a heat detector and not that very efficient. It will only activate when the tip of the soldering iron is near the sensor, about 1cm. My problem is i don't have the lens for it so i tried using it bare. Is that possible? And also, can i make a motion detection project from this without the use of lens (fresnel lens) ?
    Robert
