Ask an Expert Forum Have a question on Sensors? Ask our expert Charlie Strobel
  • Subscribers 340 subscribers
  • Views 1030 views
  • sensors
  • experts
  • ask_an_expert
  • panasonic
  • ask_the_expert
See a helpful answer?
patkelly
patkelly over 14 years ago
Expertise: imagePanasonic Sensor Products, Photoelectric, Fiber Optic, Laser, Proximity Pressure, Measurement, Safety
About Charlie: Charles is a Product Manager for Panasonic, supporting a broad line of sensors such as Photoelectric, Fiber Optic, Laser, Proximity, Pressure, Measurement, Safety and Area sensors with Static Control devices.  Whether it’s a new design or an upgrade to existing design, Charles has the project and technical expertise to support customers with their various sensor requests.
Read more about Charlie
If you need help on anything about Sensors, please post your question here!
If your not already, you'll need to login or register to ask your question - just click reply
Experts | Industry Experts | Become an Expert | Top Contributors
    i have tried several garment pattern making programs, most of them work ok, but the main problem is getting the body
    measurments you need..If I have these I can draft a pattern by hand in 45 minutes.
    I would like to use a cell phone to measure someone.  Take a short video and measure from the printed frame  I think can do this myself bud would like to have an app that could do it automaticly.
    Do you know if someone is working in this?
    Hello Charlie
    I am final year Electronics student want to make a project on wireless tsunami alert system but i didn't find which sensor do i use and how to interface it with microcontroller. Will you please guide me what i do???
    Dear Charlie,
    Of all the experts listed, I hope that you are the one that might be able to help me.
    We have an intruder alarm system that monitors the temperature of -80 deg C freezers in a room that is shared by three departments.  If any freezer rises above a certain danger level, the alarm trips and phones a mobile number with the message “alarm activation in freezer room”.  It gives no other information.  This means the phone holder has to attend the freezer room and either get the freezer back down to temperature or transfer specimens to another backup freezer.
    We wish to upgrade the system to one that has approximately 12-15 zones that can be split into 3 distinct areas which are associated with a phone number each.  The idea being that when an alarm trips, in a specific area, the correct number is dialled thus alerting the correct department.  I have looked through various manuals and it is not clear if any systems will do this.  Would you be able to enlighten me regarding this.
    Thank you in anticipation.
    Regards
    Graham Palmer
  • ahmidmuhandis
    ahmidmuhandis over 12 years ago
    I am studying about ultrasonic signal and sensors. I have apply it in distance measurement, proximity, echo etc. However, looking at ultrasonic animal repellent what kind, types, or class transducer (sensor) can one use to give best result. please with physical description or part number.
    Hai Charlie,
      http://uk.farnell.com/prowave/fs-2513p/sensor-piezo-film/dp/1007374#similarProducts
    This is the pressure sensor which we gonna use for our application for sensing pressure from the cheek
    developed by tongue. By this sensor, can we accomplish our sensing requirement ??
    Waiting for reply,
    Thanking you,
    K.V
  • tobbera
    tobbera over 12 years ago
    Hi!
    Hope you can help me. I'm going to build a wind vane that senses wind direction. For this I need a rotary position sensor such as a potentiometer or encoder. Its going to be connected to and Arduino Uno
                      *360 degrees rotation without stop.
      • *Very low friction (free spinning)
      • *Resolution of at least 360 per revolution.
      • *Dead band of  up to 45 degrees is OK
      • *Ruggedness and durability is not of great concern, this is for an experiment.
      • *Bellow USD $50
    I have looked at several online, but found many to be very expensive. I have bought a BOURNS 6639S-1-103, but it simply has too much friction .
