Ask an Expert Forum Have a question on control products? Ask our expert Sydney Brooks
  • Subscribers 310 subscribers
  • Views 588 views
  • experts
  • ask_an_expert
  • panasonic
  • ask_the_expert
See a helpful answer?
patkelly
patkelly over 13 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Communications in the element14 Industrial Automation & Robotics group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Expertise: imageControl products such as Programmable Logic Controllers (PLC), Human Machine Interface (HMI), Servo Motors, Timers, Temperature Controllers, Limit Switches, Counters, Hour Meters, Eco Power Meters, and UV Curing products.
About Sydney: Sydney is a Product Manager for Panasonic, supporting a broad line of Control products such as Programmable Logic Controllers (PLC), Human Machine Interface (HMI), Servo Motors, Timers, Temperature Controllers, Limit Switches, Counters, Hour Meters, Eco Power Meters, and UV Curing products.  Whether it’s a new design or an upgrade to existing design, Sydney has the project and technical expertise to support customers with their various control requests.
Read more about Sydney
If you need help on anything about control products, please post your question here!
If your not already, you'll need to login or register to ask your question - just click reply
    sir can you tell that can I use Python with avr or not and yes then give me some ideas about it please ?
    Can you please advise on the best board to use when I build a rig that will be BOTH a 3D printer and a CNC mill. My plan is to use "Printrboard". Will there be sw for it to use for CNC milling too?
    thanks
    Per
    Hi, I'm not sure if you are the right person to ask but I need help. Firstly know nothing about motors so please bear with me. I have 6 big circular wooden cut outs that I want to rotate independently of one another but I don't know how to pick the right motor for them. The cut outs made of mdf are 1210mm in diameter. They are about 5 kgs in weight and they will be rotating off center. I have tried to calculate the torque and inertia etc, but I'm not sure if my calculations are right nor am I sure if I have understood the physics of it all. Could someone please help me choose the right motor? Honestly at this point I don't care bout how fast or show the motor rotates. I just want it to be able to rotate my piece 360 degrees.
    Any help would be greatly appreciated.
    can you suggest what wifi solution i can add to an uno robot that has two motors
    like to use wifi but where to start image
    shabaz over 11 years ago in reply to Former Member
    Hi Rick,
    You've posted this four or five times. As a suggestion, just a single entry (in Arduino or Single Board Computers) is enough, people will see it. The others can be deleted, otherwise people will respond on different threads without realizing others have already answered.  Right now I don't know which thread to respond on, so I'm hoping you decide to delete all but one.
