Ask an Expert Forum issue regarding waveform generation through Atmega16
  • Subscribers 322 subscribers
  • Views 239 views
See a helpful answer?
Sir i have to generate pulse at 4 saperate pins of atmega16 with time period of each pulse would be 250ms....so plz suggest me how can i do it...i have also studied about the delay generation concept of atmega16 MCU.sir is it possible while using a single timer(0).i also tried to generate a code...so plz check it out sr...it is not showing any error while compiling but it doesn't show the output according to me....my output pins are PB3,PD4,PD5,PD7......and my code is
#include<avr/io.h>
#include<util/delay.h>
#include<avr/interrupt.h>
void t0_init(void);
#define FREQ 1000000     // crsytal freqeuncy
#define PRECSALER 1024
#define F_OUT 4          // output frequency
#define OCR0_VALUE ((((FREQ)/PRECSALER)/F_OUT)-1)
int main()
     t0_init();               // timer initialize
     sei();                    // enable global interrupts
     while(1);
void t0_init()
     // WGM0[1:0]= 10, for CTC mode
     // COM0[1:0]= 01, to toggle OC0 on compare match
     // CS0[2:0] =010. for prescaler 8
     TCCR0=(1<<WGM01)|(1<<COM00)|(1<<CS02)|(1<<CS00);
     DDRB|=(1<<PB3);
     DDRD|=(1<<PD4)|(1<<PD5)|(1<<PD7);          // select as output pin
     TIMSK|=(1<<TOIE0);          //enable output compare interrupt
ISR(TIMER0_COMP_vect)               // interrupt subroutine
     OCR0=(uint8_t)OCR0_VALUE;     //put OCR value
