Ask an Expert Forum Help turning an old laptop webcam into a USB webcam.
  • Subscribers 340 subscribers
  • Views 3786 views
See a helpful answer?
Here is picture of how it's set up.
http://i.imgur.com/wLuprsS.jpg
To be honest I don't really know what this means, I know the yellow would connect to white, and the orange would connect to green. Then, black to green, but I don't know what to do with the blue and red wire.
Any help would be greatly appreciated, Thanks in advanced.
  • shobhitkukreti
    shobhitkukreti over 13 years ago
    How did you label the existing camera wire ? . Where are you connecting those wires. I believe, you need to supply power to your webcam. Red 3.3V should be needed for that. However, I would need more more information to decide
    e14 Contributor over 13 years ago in reply to shobhitkukreti
    It was labeled on the actual webcam, here's a picture.
  • soumitrab
    soumitrab over 13 years ago
    SHGND would refer to the shielded cable which is connected to the  system/analog ground. 3v3 (red) is your 3.3v supply rail. D+/D- are data lines (probably similar to a USB dataline). If you can get a model and make for the webcam then getting hold of the relevant datasheet would help.
    There is one thing to note though - the D+/D- may not be 5V tolerant like normal USB lines ... you may need a 3v3 zener to clamp the data line voltages.
