Ask an Expert Forum IOS Controlled 12V Switch Bank - Does it exist?
  • Subscribers 339 subscribers
  • Views 2364 views
  • 12v
  • ios
  • app
  • switch
  • bank
See a helpful answer?
I need a switch bank to control 12v lights in my van and I also want to be able to control the switches remotely either by a dedicated remote or via an iphone app which would be the best. Does anybody know of a product like this already in existence?
Thanks!
Skye
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago
    NETIO, coupled with a WIFI or other IP connection works great, i have been using it for a year and a half with great results
    see NetIO Controller
    regards
    Peter
    e14 Contributor over 12 years ago in reply to Robert Peter Oakes
    Does that only work where there is wifi? It needs to work in remote locations such as the Nevada desert. I found some smartphone controlled relays on this website https://www.controlanything.com/ but it looks like bluetooth relay control isn't supported by apple, only android (see screenshot)
    Fullscreen contentimage_176402.html Download
    <html><head><title>Jive SBS</title></head>
    <body><font face="arial,helvetica,sans-serif">
    <b>Error</b><br><font size="-1">
    An general error occurred while processing your request.
    </font></font></body></html>
    Yes, WIFI but the IPhone has the ability to be a Hot Spot so once your in range it will connect and you should be able to communicate with it, I have not tried this but I dont see any reason it will not work
    The Bluetooth option is also viable but may be more expensive depending on where you can get the sheild
    I think the product from controlanything comes with a sheild and they have an app for the relay control. Now I just need to figure out which would be better wifi and hot spot on iphone or bluetooth on android. Do you know if either will work without a network signal?
    Robert Peter Oakes over 12 years ago in reply to e14 Contributor
    By network I assume you mean a cell signal
    if so then the answer is yes it should work
    Peter
    Thats good news. Thanks for your help!
