Ask an Expert Forum conductivity/TDS/ppm meter
  • Subscribers 315 subscribers
  • Views 231 views
See a helpful answer?
i wanna conductivity/TDS/ppm meter which gives analog output in term of voltage. i wanna use this meter to measure a conductivity of liquid for my project.request you to let me inform if u have a circuit diagram for it. kindly need urgently.
thank you.
  • sanuzr
    sanuzr over 11 years ago
    Dear Rinkal,
    To measure conductivity of liquid, you need two probes one of which will be used to inject a pulsed signal of about 100kHz and other will be used to sense the same injected signal and measure the amplitude of the same. To measure the amplitude you need an active rectifier (based on Op-Amp and four diodes configured as bridge and put in place of the feedback resistor of a traditional amplifier. Add another stage of amplifier for your gain requirement.
    Sujit
