Ask an Expert Forum i have one doubt with work in allegro pcb editor which was my board file has 4 sub board file. shall i create different layer configuration for each sub board???????????
  • Subscribers 314 subscribers
  • Views 367 views
See a helpful answer?
i need the help for above thing
  • vsluiter
    vsluiter over 11 years ago
    Can you explain a bit more in detail what you want to do? Are you making 4 boards in one design file? And what do you mean with layer configurations? I'm working with Allegro 16.6 myself, so might give you some help
    Former Member over 11 years ago in reply to vsluiter
    hi,
    thanks for your response. My customer needs four board as a stack-up and specific component structure for each.In that first and fourth board does not have more component 2 layer is enough for that routing of that. But second one has FPGA. So it requires minimum 4 layers. I am also do in Allegro 16.6 only
