Ask an Expert Forum Looking for somebody to hire for quick Arduino related job
  • Subscribers 338 subscribers
  • Views 694 views
  • exlar
  • frontpage
See a helpful answer?
Hi!
I am vaguely familiar with Arduino programming but for my next trick I will need some help.
The job:
Make this linear actuator:
Tritex II DC Linear Actuator — TritexTm Integrated Products | Exlar
controllable with this pressure differential:
MPXV7002DP Freescale Semiconductor | Mouser
The actuator will go to the center of the range when no pressure is applied, and go either way according to whether the user sucks or blows into a straw, of course the signal is analog. The linear actuator will be used to steer a vehicle I am building that you can see here:
The Spider Crab Blog
Please contact me if you or anybody you know is capable of making this happen, or if you have suggestions.
Thank you,
Skye
    dougw over 11 years ago
    Hi Skye,
    I don't think you need an arduino at all. This actuator can respond directly and proportionally to an analog voltage such as the voltage produced by the sensor. You may need to adjust offset and amplification, but it looks like the actuator can probably handle these adjustments using its own programmable setup.
    Doug
    e14 Contributor over 11 years ago in reply to dougw
    Cool! Thanks Doug! I might still want the arduino to lessen the steering amount when traveling faster but that is awesome news, thank you. I should mention also that I am in Pacifica, CA (bay area)
    dougw over 11 years ago in reply to e14 Contributor
    An arduino would work, but you could also avoid programming by having a simple analog circuit that would attenuate the control signal in proportion to the speed.
