Ask an Expert Forum Help.....getting an out of bound exeception
  • Subscribers 302 subscribers
  • Views 263 views
  • help
  • experts
  • programming
  • ask_the_expert
See a helpful answer?
I am trying to get the code below to distort an image. The distortion creates square bumps on the image surface.
The code below keeps giving me an out of bounds exeception. Hope someone could find the problem.
PImage img;
PImage img_new;
int cellsize=2;
int cols, rows;
void setup(){
size(600,600);
img=loadImage("bcircle.jpg");
img_new=createImage(img.width,img.height,RGB);
cols = width/cellsize;
rows = height/cellsize;
void draw(){
  img.resize(img.width,img.height);
  img_new.loadPixels();
  int shif=0;
  for(int j=0; j<rows; j++){
    for(int i=0; i<cols; i++){
     int x=i*cellsize+cellsize/2;
     int y=j*cellsize+cellsize/2;
     int loc=x+width*y;
     int left_loc=(x-cellsize)+width*y;
     if(x>cellsize && x<width-cellsize && shif%2==0){
       img_new.pixels[loc] = color (img.pixels[left_loc]);
     }else{
       img_new.pixels[loc] = color (img.pixels[loc]);
   shif++;
   img_new.updatePixels();
   image(img_new,0,0);
  • gadget.iom
    gadget.iom over 10 years ago
    Hi Eddy
    I haven't run the code myself, but one thing that may be an issue:
    In the above line for example, you may need to either begin with j at 1 or subtract 1 from the rows variable.
  • gadget.iom
    Hi Eddy.
    Ignore my last post. It's looked like you were using processing, so I downloaded a copy and attempted to replicate the issue.
    I have no experience with processing and the code works with an image of 600pxx600px and above,  but it seems to fail when the image falls below that size.
    Is the bcirgle.jpg image you're using 600x600?
    I have now modified the code so that it loads the image first and defines the canvas based on the dimensions determined from the image itself. This means you can have an image of any dimensions, even non square ones. (Hopefully)
    Code:
    PImage img;
    PImage img_new;
    int cellsize=2;
    int cols, rows;
    void setup(){
    //size(600,600);
    size(img.width, img.height);
    void draw(){
      int shif=0;
         int loc=x+width*y;
         }else{
       shif++;
       image(img_new,0,0);
    Line 8 has been commented out and line 10 added. Let me know how you get on.
    Paul
