Ask an Expert Forum Monitoring Water Level in a Tank
  • Replies 58 replies
  • Subscribers 341 subscribers
  • Views 7161 views
  • monitoring
  • water
  • level
See a helpful answer?
I wan to automate a test that I conduct frequently.  I want to record the drop in water level in a water tank over 30 minutes then trigger a valve with solenoid (able to operate by gravity flow, no pressured water) to refill the water back to same level and then wait another 30 minutes.  Each time interval will have a set of data representing the water level in the tank.  I was told I need a microcontroller, an e-tape (from Milone technologies) and a water valve.  Can anyone help in pointing out what instruments are needed and how to connect them.  I was told that I don't need a data logger if the controller can control a valve and log data.  If someone an help , I will draw a sketch if needed. Regards
    dougw over 11 years ago in reply to e14 Contributor +1
    https://www.sparkfun.com/products/12772 https://oceancontrols.com.au/KTA-265.html
    e14 Contributor over 11 years ago +1
    I am working on a similar project, where I measure the water level in a tank and according to the level in the tank the micro controller must switch two pump on or of independently. The equipment I am…
    e14 Contributor over 11 years ago in reply to e14 Contributor
    Doug, I found the PSoC4 Pioneer Kit on Element 14 Community. Please let me know where to get the water level sensor.
    I am buying the kit now.
    The method I would choose is based on my knowledge and capabilities. Your choice should be based on your knowledge, capabilities and availability of time and resources.
    My way involves designing and building a capacitance probe, designing and building a capacitance measurement circuit, connecting it to a PSoC4 microcontroller, programming the microcontroller to handle the valve, the timing, data capture, datalogging, data scaling and data reporting.
    If you want to avoid some of the learning associated with doing it the way I would do it, there are other solutions such as the e-tape sensor and the Sparkfun Logomatic module. The e-tape sensor would also work well with a PSoC4 microcontroller. But all of these solutions involve some design work.
    e14 Contributor over 11 years ago in reply to dougw
    Can you call me. 951-534-1618.
  • D_Hersey
    D_Hersey over 11 years ago
    Water Level Sensor
    e14 Contributor over 11 years ago in reply to D_Hersey
    cool.  do you know how to hook it up to a controller so it can open the water valve and close it when water level reaches the full depth and then monitor the water drops and record the data (time vs depth) for 30 minutes.  then open valve again until water reaches full level, stop the valve and let the water drops again.  My issue is not knowing the programing part.  I bought almost everything mentioned in the above emails, but need direction to move forward.  I will buy this item. if you can take a stab at the programing.  Controller/logger, sensor, valve.  If you know someone who is willing to take the time to work on it.  I tried to have Doug (see the thread above) help out, but he may be busy.
  • D_Hersey
    Let's have a little back story, maybe some diagrams or pictures.
    You got it.  give me few minutes
    I could not download the PDF into this email, so I copied it and past it
    Do you see the sketch Don?
    its not showing on my end
  • D_Hersey
    Nope, I just get a blank rectangle.
