Ask an Expert Forum BeagleBone Black does not boot by kernel panic
  • Subscribers 314 subscribers
  • Views 429 views
See a helpful answer?
After a few weeks using my new BBB it suddenly stop booting.
Apparently the problem is because I'm using older versions or because I have connected devices at the boot moment.
Now, I did check these newer releases connecting only the power supply to the BBB.
     bone-debian-7.7-console-armhf-2014-12-31-2gb.img
     BBB-eMMC-flasher-debian-7.7-console-armhf-2014-12-31-2gb.img
     bone-debian-7.7-lxde-4gb-armhf-2014-12-31-4gb.img
     BBB-eMMC-flasher-debian-7.7-lxde-armhf-2014-12-31-2gb.img
The sequence of LEDS start blinking but abruptly only the User LED 2 remains on, whenever I try booting from flash, SD card or flashing.
I'll appreciate some enlightenment.
Arturo
----The following output appears connecting a USB-TTL serial-----
U-Boot SPL 2015.01-rc4-00002-g76c2d3b (Dec 30 2014 - 20:48:45)
U-Boot 2015.01-rc4-00002-g76c2d3b (Dec 30 2014 - 20:48:45), Build: jenkins-gith5
       Watchdog enabled
I2C:   ready
DRAM:  512 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Using default environment
Net:   <ethaddr> not set. Validating first E-fuse MAC
Phy 0 not found
cpsw
Hit any key to stop autoboot:  0
gpio: pin 53 (gpio 53) value is 1
switch to partitions #0, OK
mmc0 is current device
gpio: pin 54 (gpio 54) value is 1
Checking for: /uEnv.txt ...
reading uEnv.txt
760 bytes read in 6 ms (123 KiB/s)
gpio: pin 55 (gpio 55) value is 1
Loaded environment from uEnv.txt
Importing environment from mmc ...
Checking if uenvcmd is set ...
gpio: pin 56 (gpio 56) value is 1
Running uenvcmd ...
721 bytes read in 73 ms (8.8 KiB/s)
5606008 bytes read in 365 ms (14.6 MiB/s)
2868890 bytes read in 221 ms (12.4 MiB/s)
26098 bytes read in 114 ms (222.7 KiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x558a78 ]
## Flattened Device Tree blob at 88000000
   Booting using the fdt blob at 0x88000000
   Loading Ramdisk to 8fd43000, end 8ffff69a ... OK
   Loading Device Tree to 8fd39000, end 8fd425f1 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.8.13-bone68 (root@a5-imx6q-wandboard-2gb) (gcc v4
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie
[    0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335e
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES2.1 (l2cache sgx neon )
[    0.000000] PERCPU: Embedded 9 pages/cpu @c0d41000 s14080 r8192 d14592 u36864
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pa2
[    0.000000] Kernel command line: console=tty0 console=ttyO0,115200n8 root=/dh
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] __ex_table already sorted, skipping sort
[    0.000000] allocated 1048576 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memos
[    0.000000] Memory: 511MB = 511MB total
[    0.000000] Memory: 505396k/505396k available, 18892k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
[    0.000000]       .text : 0xc0008000 - 0xc07f0910   (8099 kB)
[    0.000000]       .init : 0xc07f1000 - 0xc082e700   ( 246 kB)
[    0.000000]       .data : 0xc0830000 - 0xc08b7740   ( 542 kB)
[    0.000000]        .bss : 0xc08b7740 - 0xc0930f00   ( 486 kB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] NR_IRQS:0 nr_irqs:0 0
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrus
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 1789s
[    0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty0] enabled
[    0.000638] Calibrating delay loop... 993.47 BogoMIPS (lpj=969728)
[    0.029194] pid_max: default: 32768 minimum: 301
[    0.029340] Security Framework initialized
[    0.029406] Mount-cache hash table entries: 512
[    0.035137] Initializing cgroup subsys cpuacct
[    0.035183] Initializing cgroup subsys memory
[    0.035230] Initializing cgroup subsys blkio
[    0.035326] CPU: Testing write buffer coherency: ok
[    0.035720] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[    0.035788] Setting up static identity map for 0x804d3708 - 0x804d3754
[    0.036728] Brought up 1 CPUs
[    0.036757] SMP: Total of 1 processors activated (993.47 BogoMIPS).
[    0.037561] devtmpfs: initialized
[    0.045903] omap_hwmod: wd_timer2: _wait_target_disable failed
[    0.098049] pinctrl core: initialized pinctrl subsystem
[    0.098202] rstctl core: initialized rstctl subsystem
[    0.098487] regulator-dummy: no parameters
[    0.098814] NET: Registered protocol family 16
[    0.099356] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.104986] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.105617] platform 49000000.edma: alias fck already exists
[    0.105647] platform 49000000.edma: alias fck already exists
[    0.105669] platform 49000000.edma: alias fck already exists
[    0.106386] OMAP GPIO hardware version 0.1
[    0.108925] gpio-rctrl rstctl.4: loaded OK
[    0.112260] No ATAGs?
[    0.112283] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.113599] cpsw.0: No hwaddr in dt. Using d0:39:72:40:c6:aa from efuse
[    0.113637] cpsw.1: No hwaddr in dt. Using d0:39:72:40:c6:ac from efuse
[    0.121676] bio: create slab <bio-0> at 0
[    0.127916] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[    0.128211] vmmcsd_fixed: 3300 mV
[    0.129808] SCSI subsystem initialized
[    0.130060] usbcore: registered new interface driver usbfs
[    0.130131] usbcore: registered new interface driver hub
[    0.130350] usbcore: registered new device driver usb
[    0.131618] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    0.132552] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-00
[    0.134173] DCDC1: at 1500 mV
[    0.135045] vdd_mpu: 925 <--> 1325 mV at 1325 mV
[    0.135866] vdd_core: 925 <--> 1150 mV at 1125 mV
[    0.136727] LDO1: at 1800 mV
[    0.137531] LDO2: at 3300 mV
[    0.139058] LDO3: 1800 mV
[    0.139871] LDO4: at 3300 mV
[    0.140598] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    0.141082] omap_i2c 44e0b000.i2c: unable to select pin group
[    0.141564] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[    0.143036] omap_i2c 4819c000.i2c: unable to select pin group
[    0.143204] media: Linux media interface: v0.10
[    0.143275] Linux video capture interface: v2.00
[    0.143351] pps_core: LinuxPPS API ver. 1 registered
[    0.143367] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[    0.143775] Advanced Linux Sound Architecture Driver Initialized.
[    0.144366] NetLabel: Initializing
[    0.144388] NetLabel:  domain hash size = 128
[    0.144470] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.144577] NetLabel:  unlabeled traffic allowed by default
[    0.144768] Switching to clocksource gp_timer
[    0.176323] NET: Registered protocol family 2
[    0.176987] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.177085] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[    0.177176] TCP: Hash tables configured (established 4096 bind 4096)
[    0.177249] TCP: reno registered
[    0.177270] UDP hash table entries: 256 (order: 1, 12288 bytes)
[    0.177302] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[    0.177542] NET: Registered protocol family 1
[    0.177943] RPC: Registered named UNIX socket transport module.
[    0.177968] RPC: Registered udp transport module.
[    0.177982] RPC: Registered tcp transport module.
[    0.177995] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.178278] Trying to unpack rootfs image as initramfs...
[    0.372679] Freeing initrd memory: 2800K
[    0.373021] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 countee
[    0.373303] CPU PMU: attempt to register multiple PMU devices!
[    0.373413] arm-pmu: probe of arm-pmu failed with error -28
[    0.373733] omap2_mbox_probe: platform not supported
[    0.523900] VFS: Disk quotas dquot_6.5.2
[    0.524065] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.524821] NFS: Registering the id_resolver key type
[    0.524930] Key type id_resolver registered
[    0.524945] Key type id_legacy registered
[    0.525215] fuse init (API version 7.20)
[    0.525627] Btrfs loaded
[    0.525812] msgmni has been set to 992
[    0.527446] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    0.527486] io scheduler noop registered
[    0.527500] io scheduler deadline registered
[    0.527529] io scheduler cfq registered (default)
[    0.528746] tps65217-bl tps65217-bl: no platform data provided
[    0.528786] tps65217-bl: probe of tps65217-bl failed with error -22
[    0.529313] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.530692] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[    0.530995] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP U0
[    1.290844] console [ttyO0] enabled
[    1.295178] [drm] Initialized drm 1.1.0 20060810
[    1.307296] brd: module loaded
[    1.314228] loop: module loaded
[    1.317638] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.324880] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.332111] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.339351] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.346593] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.360497] bone-capemgr bone_capemgr.9: Baseboard: 'A335BNLT,00A5,5002BBBK8'
[    1.368307] bone-capemgr bone_capemgr.9: compatible-baseboard=ti,beaglebone-k
[    1.406563] bone-capemgr bone_capemgr.9: slot #0: No cape found
[    1.443670] bone-capemgr bone_capemgr.9: slot #1: No cape found
[    1.480778] bone-capemgr bone_capemgr.9: slot #2: No cape found
[    1.517888] bone-capemgr bone_capemgr.9: slot #3: No cape found
[    1.524119] bone-capemgr bone_capemgr.9: slot #4: specific override
[    1.530702] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at4
[    1.538734] bone-capemgr bone_capemgr.9: slot #4: 'Bone-LT-eMMC-2G,00A0,Texa'
[    1.548829] bone-capemgr bone_capemgr.9: slot #5: specific override
[    1.555411] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at5
[    1.563423] bone-capemgr bone_capemgr.9: slot #5: 'Bone-Black-HDMI,00A0,Texa'
[    1.573404] bone-capemgr bone_capemgr.9: slot #6: specific override
[    1.579972] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at6
[    1.587996] bone-capemgr bone_capemgr.9: slot #6: 'Bone-Black-HDMIN,00A0,Tex'
[    1.598413] bone-capemgr bone_capemgr.9: loader: before slot-4 BB-BONE-EMMC-)
[    1.607279] bone-capemgr bone_capemgr.9: loader: check slot-4 BB-BONE-EMMC-2)
[    1.616099] bone-capemgr bone_capemgr.9: loader: before slot-5 BB-BONELT-HDM)
[    1.624855] bone-capemgr bone_capemgr.9: loader: check slot-5 BB-BONELT-HDMI)
[    1.633522] bone-capemgr bone_capemgr.9: initialized OK.
[    1.639096] bone-capemgr bone_capemgr.9: loader: before slot-6 BB-BONELT-HDM)
[    1.647929] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMI)
[    1.658094] OneNAND driver initializing
[    1.663044] usbcore: registered new interface driver cdc_ether
[    1.669205] bone-capemgr bone_capemgr.9: loader: after slot-4 BB-BONE-EMMC-2)
[    1.678002] usbcore: registered new interface driver rndis_host
[    1.684259] bone-capemgr bone_capemgr.9: loader: after slot-5 BB-BONELT-HDMI)
[    1.692929] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMI)
[    1.701738] usbcore: registered new interface driver cdc_ncm
[    1.707695] bone-capemgr bone_capemgr.9: slot #4: Requesting firmware 'cape-'
[    1.721736] usbcore: registered new interface driver cdc_acm
[    1.727690] cdc_acm: USB Abstract Control Model driver for USB modems and ISs
[    1.736076] Initializing USB Mass Storage driver...
[    1.741207] bone-capemgr bone_capemgr.9: slot #4: dtbo 'cape-bone-2g-emmc1.de
[    1.751887] bone-capemgr bone_capemgr.9: slot #5: Requesting firmware 'cape-'
[    1.766054] usbcore: registered new interface driver usb-storage
[    1.772345] USB Mass Storage support registered.
[    1.777387] bone-capemgr bone_capemgr.9: slot #4: #2 overlays
[    1.784013] bone-capemgr bone_capemgr.9: slot #4: Applied #2 overlays.
[    1.790895] bone-capemgr bone_capemgr.9: loader: done slot-4 BB-BONE-EMMC-2G)
[    1.799591] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMI)
[    1.808363] bone-capemgr bone_capemgr.9: slot #5: dtbo 'cape-boneblack-hdmi-e
[    1.819712] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    1.826277] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[    1.831510] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:480 dspK
[    1.840789] bone-capemgr bone_capemgr.9: slot #5: #4 overlays
[    1.848265] platform 4830e000.fb: alias fck already exists
[    1.854242] musb-hdrc musb-hdrc.0.auto: *** mode=3
[    1.859304] musb-hdrc musb-hdrc.0.auto: *** power=250
[    1.865652] bone-capemgr bone_capemgr.9: slot #5: Applied #4 overlays.
[    1.872518] bone-capemgr bone_capemgr.9: loader: done slot-5 BB-BONELT-HDMI:)
[    1.881104] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMI)
[    1.890298] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[    1.895544] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:480 dspK
[    1.904299] bone-capemgr bone_capemgr.9: loader: after slot-6 BB-BONELT-HDMI)
[    1.913246] musb-hdrc musb-hdrc.1.auto: *** mode=1
[    1.918297] musb-hdrc musb-hdrc.1.auto: *** power=250
[    1.923602] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.929656] bone-capemgr bone_capemgr.9: slot #6: Requesting firmware 'cape-'
[    1.944163] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus1
[    1.952524] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.959669] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    1.967257] usb usb1: Product: MUSB HDRC host driver
[    1.972450] usb usb1: Manufacturer: Linux 3.8.13-bone68 musb-hcd
[    1.978739] usb usb1: SerialNumber: musb-hdrc.1.auto
[    1.983990] bone-capemgr bone_capemgr.9: slot #6: dtbo 'cape-boneblack-hdmine
[    1.995493] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P)
[    2.005087] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[    2.011832] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BO)
[    2.022242] hub 1-0:1.0: USB hub found
[    2.026235] hub 1-0:1.0: 1 port detected
[    2.031259] mousedev: PS/2 mouse device common for all mice
[    2.038667] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[    2.046362] i2c /dev entries driver
[    2.051038] pps_ldisc: PPS line discipline registered
[    2.056487] Driver for 1-wire Dallas network protocol.
[    2.063053] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    2.070732] device-mapper: ioctl: 4.23.1-ioctl (2012-12-18) initialised: dm-m
[    2.079624] cpuidle: using governor ladder
[    2.083937] cpuidle: using governor menu
[    2.088373] omap_hsmmc mmc.5: of_parse_phandle_with_args of 'reset' failed
[    2.095584] omap_hsmmc mmc.5: Failed to get rstctl; not using any
[    2.102259] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[    2.109426] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[    2.116694] mmc.5 supply vmmc_aux not found, using dummy regulator
[    2.123532] omap_hsmmc mmc.5: pins are not configured from the driver
[    2.156791] gpio-rctrl rstctl.4: gpio_rctrl_request eMMC_RSTn
[    2.162960] omap_hsmmc mmc.11: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMn
[    2.170937] gpio-rctrl rstctl.4: gpio_rctrl_deassert eMMC_RSTn
[    2.177272] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[    2.184369] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[    2.191743] mmc.11 supply vmmc_aux not found, using dummy regulator
[    2.198425] omap_hsmmc mmc.11: pins are not configured from the driver
[    2.233047] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested b8
[    2.244715] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[    2.252008] pinctrl-single 44e10800.pinmux: could not request pin 21 on devie
[    2.260953] leds-gpio gpio-leds.8: pins are not configured from the driver
[    2.268901] ledtrig-cpu: registered to indicate activity on CPUs
[    2.275467] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[    2.282635] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    2.290107] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    2.296336] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[    2.303496] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[    2.313527] usbcore: registered new interface driver usbhid
[    2.319450] usbhid: USB HID core driver
[    2.324328] ashmem: initialized
[    2.327740] mmc0: host does not support reading read-only switch. assuming w.
[    2.336479] logger: created 256K log 'log_main'
[    2.341490] logger: created 256K log 'log_events'
[    2.346552] mmc0: new high speed SDHC card at address 1234
[    2.352522] logger: created 256K log 'log_radio'
[    2.357866] mmcblk0: mmc0:1234 SA16G 14.6 GiB
[    2.362759] logger: created 256K log 'log_system'
[    2.369913]  mmcblk0: p1 p2
[    2.375050] davinci_evm sound.14:  nxp-hdmi-hifi <-> 48038000.mcasp mapping k
[    2.384731] TCP: cubic registered
[    2.388365] NET: Registered protocol family 10
[    2.393820] NET: Registered protocol family 17
[    2.398854] Key type dns_resolver registered
[    2.403512] VFP support v0.3: implementor 41 architecture 3 part 30 variant 3
[    2.411649] ThumbEE CPU extension supported.
[    2.416172] Registering SWP/SWPB emulation handler
[    2.421867] registered taskstats version 1
[    2.427915] tilcdc 4830e000.fb: No power control GPIO
[    2.484621] mmc1: BKOPS_EN bit is not set
[    2.492723] mmc1: new high speed MMC card at address 0001
[    2.498967] mmcblk1: mmc1:0001 MMC04G 3.60 GiB
[    2.503978] mmcblk1boot0: mmc1:0001 MMC04G partition 1 2.00 MiB
[    2.510392] mmcblk1boot1: mmc1:0001 MMC04G partition 2 2.00 MiB
[    2.517660]  mmcblk1: p1 p2
[    2.522285]  mmcblk1boot1: unknown partition table
[    2.528630]  mmcblk1boot0: unknown partition table
[    2.553552] tilcdc 4830e000.fb: found TDA19988
[    2.558808] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[    2.565737] [drm] No driver support for vblank timestamp query.
[    2.572217] tilcdc 4830e000.fb: No connectors reported connected with modes
[    2.579524] [drm] Cannot find any crtc or sizes - going 1024x768
[    2.595082] Console: switching to colour frame buffer device 128x48
[    2.607780] tilcdc 4830e000.fb: fb0:  frame buffer device
[    2.613497] tilcdc 4830e000.fb: registered panic notifier
[    2.619238] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[    2.674157] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[    2.680651] davinci_mdio 4a101000.mdio: no live phy, scanning all
[    2.687348] davinci_mdio: probe of 4a101000.mdio failed with error -5
[    2.694428] Detected MACID = d0:39:72:40:c6:aa
[    2.699039] Unhandled fault: external abort on non-linefetch (0x1008) at 0xe0
[    2.707366] Internal error: : 1008 [#1] SMP THUMB2
[    2.712451] Modules linked in:
[    2.715705] CPU: 0    Not tainted  (3.8.13-bone68 #1)
[    2.721078] PC is at cpsw_probe+0x348/0x960
[    2.725523] LR is at ioremap_page_range+0x95/0xf8
[    2.732827] pc : [<c032552c>]    lr : [<c0255c75>]    psr: a0000033
[    2.732827] sp : df071e18  ip : 00000000  fp : df0d3400
[    2.749501] r10: c082ab94  r9 : de5f9800  r8 : de5f9d90
[    2.757301] r7 : de5f9800  r6 : de5f9d40  r5 : 00000000  r4 : e089c000
[    2.766457] r3 : 80000000  r2 : 00000000  r1 : e089d000  r0 : e089c000
[    2.775568] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA Thumb  Segment kl
[    2.785724] Control: 50c5387d  Table: 9e268019  DAC: 00000015
[    2.794081] Process swapper/0 (pid: 1, stack limit = 0xdf070240)
[    2.802772] Stack: (0xdf071e18 to 0xdf072000)
[    2.809738] 1e00:                                                       00009
[    2.820732] 1e20: c0877bb8 c0877bb8 de5f9d40 de5f9a98 df0d3410 de5fc8c8 00000
[    2.831706] 1e40: df071e90 c00ff1b3 22222222 22222222 00000000 c0877bb8 de5f0
[    2.842700] 1e60: de5fc8c8 c00ff0ef de5fc8c8 00000000 df071e90 de5fc948 df0d7
[    2.853720] 1e80: df0494b8 c0049697 00000000 df0d3444 00000020 00000008 df0dc
[    2.864765] 1ea0: df0d3410 c0896c40 00000000 c080d039 00000100 c082ab94 00009
[    2.875832] 1ec0: c02c8269 c02c771b 00000000 df0d3410 c0896c40 df0d3444 0000b
[    2.886905] 1ee0: c0896c40 c02c7831 00000000 c02c684f df049478 df0c4180 c0890
[    2.897970] 1f00: de262340 c02c720f c073906c c0896c40 c0896c40 df070000 c08b0
[    2.909049] 1f20: c080d039 c02c7b7d 00000000 c08177b0 df070000 c08b7740 00009
[    2.920145] 1f40: 00000100 c000867f 00000007 00000007 c086fc98 c08177ac c0817
[    2.931294] 1f60: c0817790 c08b7740 c07f11c9 c082ab94 00000000 c07f16a3 00007
[    2.942468] 1f80: c07f11c9 c0d43fc0 00000000 c04c61c9 00000000 00000000 00000
[    2.953645] 1fa0: 00000000 c04c61cf 00000000 c000c8fd 00000000 00000000 00000
[    2.964832] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000
[    2.976004] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000
[    2.987136] [<c032552c>] (cpsw_probe+0x348/0x960) from [<c02c8279>] (platfor)
[    2.999120] [<c02c8279>] (platform_drv_probe+0x11/0x14) from [<c02c771b>] (d)
[    3.011838] [<c02c771b>] (driver_probe_device+0x53/0x168) from [<c02c787b>] )
[    3.024334] [<c02c787b>] (__driver_attach+0x4b/0x4c) from [<c02c684f>] (bus_)
[    3.036481] [<c02c684f>] (bus_for_each_dev+0x27/0x48) from [<c02c720f>] (bus)
[    3.048653] [<c02c720f>] (bus_add_driver+0xe3/0x168) from [<c02c7b7d>] (driv)
[    3.060781] [<c02c7b7d>] (driver_register+0x3d/0xc4) from [<c000867f>] (do_o)
[    3.072901] [<c000867f>] (do_one_initcall+0x1f/0xf4) from [<c07f16a3>] (kern)
[    3.085602] [<c07f16a3>] (kernel_init_freeable+0xc3/0x158) from [<c04c61cf>])
[    3.097886] [<c04c61cf>] (kernel_init+0x7/0x98) from [<c000c8fd>] (ret_from_)
[    3.109458] Code: f000 81d2 f8c7 05c0 (6803) f44f
[    3.117292] ---[ end trace 827194fc7d813ac2 ]---
[    3.125125] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0b
[    3.125125]
[    3.140302] drm_kms_helper: panic occurred, switching back to text console
