Ask an Expert Forum Mosfet for 10KV @ 10A (500KHz)rating for the inverter application
  • Replies 12 replies
  • Subscribers 340 subscribers
  • Views 2577 views
See a helpful answer?
Hello Everybody!!!!!!!!
I am working on a concept that requires a high voltage(>5KV) inverter application, the load current will be (5-10A) and the switching frequency will be 500 to 1000 KHz i need suggestions on the availability and their pros and corns.I must be thankful if any body has worked on it previously and can share some info about it.
    michaelkellett over 11 years ago
    A 50kW inverter is a big design task - and a 50kW supply at 5KV is a scary kind of thing. What are you planning to do with it ?
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to michaelkellett
    Why.... Take over the WORLD of course... Muhhhaaaaahaaaaa
    e14 Contributor over 11 years ago in reply to michaelkellett
    thank for ur response the application is ac-dc converter with high frequency inverter in between
    michaelkellett over 11 years ago in reply to e14 Contributor
    That doesn't tell me anything  - how about posting  a block diagram showing the power source (voltages, currents, phases, frequencies) and the stages of the converter and the output. What is the load ?
    welding
    What sort of welding needs 10kV ?
    (seems  a bit low for electron beam welding)
    special welding is it possible to have a mostfet @5 to 10kv @5A
    if current is problem we can use parallel config i think
    Robert Peter Oakes over 11 years ago in reply to e14 Contributor
    This is still very experemental and a very obvious google shows this
    http://lmgtfy.com/?q=mosfet+10kv+5A
    I'm sorry but your questions don't  really make much sense. If you are contemplating building a 50kW inverter you need to be way beyond the level of asking simple questions about devices on forums. When you've looked at Peter's link just take a look at some 50KW inverters on the web (there are lots) and you'll see that typically they are about the size of a (big) fridge freezer and weight about 500kG or more - and these are low voltage (500V DC, 240V AC) machines.
    if you are aware of inverter type welding machines then i guess you can think that this makes sense all the time is there a way that i can have a high voltage(5KV) and low current(5A) device that can work @ >500KHz
    currently the welding  inverters are using iGBT's  1 to 2KV @ 50 to 100A. the limitation is always about the switching frequency,which i would like to eliminate
