Ask an Expert Forum Ethernet connection not working
  • Subscribers 337 subscribers
  • Views 305 views
  • connect
  • controller
  • ethernet
  • motion
  • connection
  • motor
  • connecting
See a helpful answer?
I am trying to connect to motor controller via ethernet because that is the only connection that the provided software can accept. I have connected via rs232 with an adapter to usb, but when i send command to the controller through a terminal i get no response. If anyone could suggest anything or maybe explain how to connect via ethernet step by step i would be very greatful. The controller that i am using is PImiCos SMC-hydra CM, 2 axis motion controller. Thank you
