Ask an Expert Forum Video Sync
  • Subscribers 338 subscribers
  • Views 390 views
  • board
  • video
  • ask_an_expert
  • sync
  • camera
  • ask
See a helpful answer?
Video Sync
I'm looking for a cheap easy way to sync video signals at my TV station. The camera that i want to use (below) does not have a sync input, any ideas?
China‘s Famous brand headsets&Headphones--------All in Douk!!!!
1920*1080P HD-SDI Board Camera Panasonic 2MP D-WDR 3D-DNR IR-Cut Filter OSD FPV
Product Description:
  • This is a HD-SDI board camera with 1/3 inch Panasonic 2 megapixel processor. It supports HD-SDI 1080P and 720P digital high definition output, WDR (Wide Dynamic Range), 3D-DNR (3D Digital Noise Reduction), D-WDR (Digital Wide Dynamic Range),motion detection and other functions, Built-in IR-CUT filter, configures megapixel CS lens, 38mm x 38mm dimensions only, suitable for DIY users.
Features:
  • 1/3'' Panasonic 2 Megapixel
  • Default HD 4mm Lens (6mm, 8mm, 12mm, 16mm optional)
  • Full HD 2 Megapixel (1080P)
  • 1080@30P/25P; 720@60/50P
  • Wide Dynamic Range (WDR)
  • 3D Digital Noise Reduction (3D-DNR)
  • Digital Wide Dynamic Range (D-WDR)
  • Defog, Motion detection, Privacy Zone, HLC (High Light Compensation), BLC (Black Light Compensation)
  • Built-in IR-CUT filter
  • HD-SDI Output
  • CVBS BNC output
  • DC12V input
Note:
  • This product is HD-SDI digital output signal and is not compatible with analog DVR devices
  • clem57
    0 clem57 over 11 years ago
    Read https://en.wikipedia.org/wiki/Serial_digital_interface which shows how to find the sync signal in the stream of 10 bit packets.
    clem
    Edit:
    The synchronization packet consists of four 10-bit words, the first three words are always the same—0x3FF, 0, 0; the fourth consists of 3 flag bits, along with an error correcting code. As a result, there are 8 different synchronization packets possible.
