Ask an Expert Forum 13 pin din connection
  • Replies 7 replies
  • Subscribers 340 subscribers
  • Views 5112 views
See a helpful answer?
demesauce
demesauce over 11 years ago
SO I recently bought a cheap 9" tat display for a Pi project.  When I opened the box, I was surprised to see this odd looking connector.  It is designed for 4 inputs (with sound I think).  Has anyone seen anything like this, or know how to wire it?  I just need on input.  And It can just be video, I'll deal with audio later.  I think I'll have to use RCA as the input which is fine.  But I can't get anything but a blue screen.
Any help is greatly appreciated
    0 shabaz over 11 years ago
    Is there an accessory cable that converts from that connector to RCA style (composite/phono video/audio) connectors?
    If not, you may need to check with the vendor for a pinout (or attempt to reverse engineer by taking it apart but that may be difficult).
    0 mcb1 over 11 years ago
    This might help.
    http://www.atari-forum.com/viewtopic.php?t=17412
    You could always ask the vendor for information about connecting it.
    Usually these multi connectors have separate colour and sync ..which might not be available.
  • demesauce
    0 demesauce over 11 years ago in reply to shabaz
    There is a connector.  One end is the 13 pin connection, the other end has four 4-pin connections, was well as power, ground, and wires that when hot will automatically select the video input.  Looks like I will try to reverse engineer.  The seller on eBay doesn't know the manufacturer and there are no labels and all serial numbers come up empty
  • demesauce
    0 demesauce over 11 years ago in reply to demesauce
    Wow, I think I may have something.  I'm getting some video, but there is a blue line across the bottom of the display.
    I can't find any pinout diagrams online.
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to demesauce
    Is this of any help?
  • demesauce
    0 demesauce over 11 years ago in reply to gadget.iom
    Thanks man, but that pinout does not seem to match up with mine.  I can't really test it at the moment either.  The only RCA output device I have is a DLR camera, and I remember reading their composite is kinda funky.  Hopefully my 3.5mm to composite will arrive soon for my Pi.
  • demesauce
    What I ended up doing was hijack a 4 pole 3.5mm plug and take the video and ground connections from there. I was able to find video, luckily there was 1 pin that runs the video line. It works, kinda. Video looks pretty bad, its not centered and is fuzzy, but at least it works. I am hoping it partly sucks cause of how I hacked the video together, but I realize composite video was never that good to begin with. I'm gonna mess around with the config.txt to see if I can clear it up some.
    Can you output specific resolutions on the 3.5mm line, or does that just pertain to the HDMI output??
