Ask an Expert Forum Running xenon lamp with higher voltage?
  • Subscribers 326 subscribers
  • Views 840 views
See a helpful answer?
magnus2112
magnus2112 over 10 years ago
Yesterday i stumbled upon this realy awsome old russian xenon lamp, and i fell in love with it!
But when i checkedimage the spesifications for the electricity  it said that it needed 40V and 52A!!!image
And a power supply at that power costs a lot!
My question is, is it possible to run the lamp from a higher voltage but with les amps?.image
Links:
http://www.ebay.com/itm/Xenon-Light-Bulb-DKsT-2000-/321709301278?hash=item4ae75e5e1e
Russian Xenon Light Bulb DKST-2000
    Hey!!
    Neat find!!
    (I assume its an arc lamp rather than a flash lamp)
    Check out this link https://en.wikipedia.org/wiki/Xenon_arc_lamp and look down towards power requirements.
    In short No. You can fiddle with the voltage/current a little bit but not extremely!! Be careful with UV emissions, it might not have any coating so thar be potential loss of sight/burnt skin and other such nastiness awaiting..
    As a hint towards how to power it; lead acid batteries (car batteries ac rectified) would be one way. check this out too: http://www.edisontechcenter.org/ArcLamps.html
    Any power supply that works from a plug socket is going to need a lot of heavy gauge wire so hence the costs..
    Mike from mikeselectricstuff might be able to help, he might already have one working!!
    Short extra:
    The high current requirement is due mainly to the length of the spark gap. Finding a bulb with a smaller gap would need less overall power.
    Did you notice the light output? 1.5cd/W
