Ask an Expert Forum the 6 volt battery with 2 springs
  • Replies 7 replies
  • Answers 2 answers
  • Subscribers 339 subscribers
  • Views 4309 views
See a helpful answer?
Does one of the springs come covered? I've bought 2 today but I'm not sure if I've brought the wrong thing as one is a spring and the other just plastic. please help
    jw0752 over 10 years ago +3 suggested
    Hi Nikki, Yes the positive spring usually comes covered in a plastic cap so that it can't be shorted out. If you pull or twist the plastic the cover will come off so you can use the battery. John
    e14 Contributor over 10 years ago in reply to jw0752 +2
    thanks i'm convinced, i just have to convince my parents! I think i will have to do it when they're not looking.
    0 jw0752 over 10 years ago
    Hi Nikki,
  • scitechindian
    0 scitechindian over 10 years ago
    can you post some pictures ?
    that will be useful to solve your problem
    0 e14 Contributor over 10 years ago in reply to scitechindian
    no camera sorry. it has one spring and one plastic bit sticking up
    0 jw0752 over 10 years ago in reply to e14 Contributor
    Hi Nikki,
    Does your battery look like this?
    0 e14 Contributor over 10 years ago in reply to jw0752
    it should do but middle one is plastic
    The plastic should come off and the battery will then be usable. Here is what the same battery looks like with the plastic cap that needs to be removed.
