Ask an Expert Forum Help with understanding blueprint
  • Answers 2 answers
  • Subscribers 338 subscribers
  • Views 904 views
See a helpful answer?
So I'm 14 and I'm "self teaching" myself over electronics and I can't find out what the dashed line to bypass capacitor means on pin 7. I'm talking about the blueprint/schematic on page 5 bottom left hand corner, The "Bass boost amplifier". The LM386 data sheet which I'm referring to can be found here. https://www.google.com/url?sa=t&source=web&cd=1&rct=j&q=lm%20386%20ic&ved=0ahUKEwj2gJzRnsPJAhVGeCYKHUKnCEcQFggwMAA&url=http%3A%2F%2Fwww.ti.com%2Flit%2Fds%2Fsymlink%2Flm386.pdf&usg=AFQjCNGzxXiOYMq0jSpbJzHb23HksJdglw Sorry for the Google link, I'm on my phone
    shabaz over 10 years ago +3 verified
    The '386 has quite a high voltage gain, so if you've got long wires then there is a possibility things could become unstable, which you'll know about because you'll hear a loud squeal. The capacitor on…
  • johnbeetem
    johnbeetem over 10 years ago +2 suggested
    Dotted lines usually mean that a component is optional or only needed in certain applications. For example, it may be that with a high gain you need a capacitor from pin 7 to ground for stability. I don…
    jw0752 over 10 years ago +1 suggested
    Hi Hunter, I looked over the data sheet and they aren't very clear on pin 7 of the LM 386. I believe your answer is in the last part of the Paragraph on page 3 titled Input Biasing. They recommend putting…
  • johnbeetem
    0 johnbeetem over 10 years ago
    Dotted lines usually mean that a component is optional or only needed in certain applications.  For example, it may be that with a high gain you need a capacitor from pin 7 to ground for stability.  I don't know for sure when you'd need it -- I'm mostly a digital guy.
    0 jw0752 over 10 years ago
    Hi Hunter,
    I looked over the data sheet and they aren't very clear on pin 7 of the LM 386. I believe your answer is in the last part of the Paragraph on page 3 titled Input Biasing. They recommend putting in a 0.1 uF cap from pin 7 to ground on the higher gain configurations. The dotted line usually indicates that it is an option as opposed to a requirement. I hope this helps. You could set up your circuit and try it with and without the cap from #7 to ground.
    0 shabaz over 10 years ago
    The capacitor on pin 7 (and a capacitor across the supply rails) is good to have nearby the LM386 to make sure it is getting a stable supply that doesn't change as the LM386 is
    supplying current to the load (speaker).
    A high voltage gain is undesirable if you're connecting the LM386 to (say) a Line output from a music system, because it already has a quite high voltage output, but is excellent if
    you're doing experiments connecting the LM386 to a microphone for example. You can choose if you want a high or a low gain by selecting one of the example circuits in the datasheet.
    As John mentions, there is no harm trying the circuit with and without the capacitor, and seeing the effects. It won't damage anything.
    The '386 is quite a popular chip, you'll have fun experimenting with it. By the way, you might want to look at some beginners books to get started in electronics, it will accelerate your learning.
    0 e14 Contributor over 10 years ago in reply to shabaz
    Thank you for your help!
    0 e14 Contributor over 10 years ago in reply to jw0752
    Thanks for looking more into the datasheet for me! Your help is appreciated.
    0 e14 Contributor over 10 years ago in reply to johnbeetem
    Your help is appreciated!
